need casper mini m100 bios dump
  • bilen
    • Aug 2014
    • 632
    • istanbul
    motherboard code H310-SF110 V:1.0
    old dump :
  • bilen
    • Aug 2014
    • 632
    • istanbul
    NOBODY ?
    UP
  • bilen
    • Aug 2014
    • 632
    • istanbul
    The device shut down during the bios update. and now it doesn't open at all
    full model : casper nirvana mini pc m100
    sn : SR002090771
      • 20299
      sn : SR002090771
      Post the bios backup,even if its corrupt. Did the update come from a windows update ?
      • bilen
        • Aug 2014
        • 632
        • istanbul
        Yes it happened after a windows update
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • ruzhda
          Clean Bios dump for HP 260 G4 mini
          by ruzhda
          I am new in forum, working whit computers since Commodore 64 (own 2 defect units) And Amiga 1200,
          I taring to fix HP 260 G4 mini whit bios corrupted error , after reading and writing bios whit programmer pc is not powering on .
          I need clean dump to write new IC chip.
          07-21-2024, 08:10 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
