ASRock H110M-STX Boardview or Schematic request
  • Herbs n spices
    • Jan 2021
    • 36
    I have an ASRock Deskmini with the H110M-STX rev 1.03 motherboard. I'd like to make some modifications so if anybody can share the boardview that would be greatly appreciated! Thank you in advance. I'm also looking for any LGA3647 boardviews.
  • Rimlen
    • Apr 2015
    • 31
    • Russia
    Only 1.02 revision.
    • Herbs n spices
      • Jan 2021
      • 36
      Thank you! I doubt the difference will hinder me. I intend to add the COM port to this unit, and support for 8th/9th gen CPUs. The COM port hardware was only added to the H110M-STX/COM version, although the physical boards are the same. I should be able to simply populate the board with an ST3243 and capacitors and enable the function in the UEFI. I will update this thread with my progress.
      • Herbs n spices
        • Jan 2021
        • 36
        Success! I first used a CH341A v1.7 to save the original UEFI, and used Coffeetime v0.99 to transfer the Intel ethernet MAC address to the stock H110M-STX/COM ROM downloaded from the Deskmini H110 page. A hexeditor would have worked fine for that, but I also wanted to update the microcodes to the latest versions on platomov's database and add coffeelake CPU support. I then flashed the new UEFI with the CH341A since version checks prevented AFUwinGUI or the onboard BIOS updater from working.
        On to the hardware: I scavenged a MAX3243CAI and the 3x 0.47uF and 1x 0.1uF capacitors from an old laptop motherboard, and the serial port I soldered directly to the H110-STX since I didn't have a suitable connector. A modern ST3243E would have been faster and one size smaller parts would have been proper, but I used what I had on hand.
        I also soldered a little jumper to short PC114 and cut 2 pins out of the socket to allow Coffeelake CPUs to work.
        After all that I reassembled the PC, booted it up, and voila! I was able to connect my RS-232 devices right away.
        • Rimlen
          • Apr 2015
          • 31
          • Russia
          Good work!
          • Jasonexe
            (request) AsRock Z270M EXTREME 4 boardview
            by Jasonexe
            I got AsRock Z270M EXTREME 4 that recently stopped working, culprit is missing vcore voltage. I'd like to know if there is a boardview for this motherboard.
            Thanks in advance.
            03-31-2025, 10:23 AM
          • RioTata
            ASRock B550M-HDV Schematics & Boardview Request
            by RioTata
            I'm having a headache trying to find this boardview without the site hosting it asking me to pay an expensive membership. I'm currently having issues with this motherboard and it would help me if someone is willing to share it.
            07-23-2025, 10:56 AM
          • gabrieljma1
            Request: Full BIOS dump for ASRock Z790-CX (DDR5)
            by gabrieljma1
            I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
            The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
            I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
            10-08-2025, 03:32 PM
          • bbanana
            Request for Asrock X570 Taichi boardview
            by bbanana
            Anyone has the boardview for x570 taichi?
            If the RAM no install i can hear the beep
            The RAM installed mainboard stuck at A8 debug code and didnt boot. I used Gskill bus 2666, Gskill bus 2133, Kingston HyperX bus 2133, Cosair bus 3200.
            CPU is Ryzen 5 2600
            I measured the RAM slots nothing wrong :
            SMB DATA and SMB Clock: 3.3v
            2.5v
            0.6V
            I flashed bios already, cleaned socket, RAM slots, vvv
            Now, i dont know to do next step without boardview
            Thanks!
            04-29-2023, 12:00 PM
          • Ash_sus10
            Request for BoardView for ASUS TUF Gaming A15 (DA0NJM8C0 Rev C)
            by Ash_sus10
            I'm looking for the BoardView file for an ASUS TUF Gaming A15 motherboard, specifically DA0NJM8C0 Rev C (Quanta NJI). My repair technician has identified a power regulation issue, and we need the BoardView to trace the power lines accurately....
            07-17-2025, 03:59 AM
