Cello AIO101 ETON ET866 94v-0 E213441 Top 1.03 v BIOS
Hello!
Yes, I tried both bios.
Since I want to give a complete picture, I will write down all my observations.
The picture of the original bios already sent above was taken before the complete collapse.
Since the crash, I've been looking for a solution on this forum. I found two bios uploads for the motherboard code in the topic. Since I wanted a complete solution regarding the programming and for the recovery, I opened this topic.
I would like to thank you for the help I have received so far.
But I still need help and I will summarize it at the end of the solution so that this topic can help others.
After the crash: After pressing the power button, the screen light turns on for 5 seconds, then the screen goes dark. It does not respond to keys F2, F8, F10, ESC, I tested it several times. If I plug it into the charger while unplugged, the machine turns on by itself, but it doesn't respond to buttons (the keyboard has a USB port, because only USB connection is possible).
After the arrival of the programmer, I started to read the bios and uploaded it here?
While I was waiting for the bios you sent, I tried two other bios uploads found on the site (nb14 CLA.rar- 2 files 1MB and 8MB file, 1.1.0.1089_1.375MB_MD_PRD_RGN.rar- 1 file 8MB).
The one containing 1.1.0.1089_1.375MB_MD_PRD_RGN.rar produced the same thing that crashed and didn't respond to the buttons either.
The 1MB file containing nb14 CLA.rar already had a login logo and I was able to enter the bios, but the image flickered a lot.
With the 8MB file, this flickering stopped, but as soon as I pressed the menu button from among the screen setting buttons (on the back of the machine), the image disappeared at that moment and never came back.
Then the TRY.rar you sent arrived with the two files as you wrote. I tried both .bins in it, but it was the same as with the crashed bios. There is lighting for 5 seconds, then a black image again, it does not respond to buttons.
I am currently here.
Question: what if I clear the bios chip again, then upload the 8MB .bin with which I managed to get into the bios, and then load the 8MB .bin you sent me from there?Comment
Hello! Still no solution to my problem. I was looking for a way to somehow force the bios to open in an emulator. The purpose of this would be to be able to reset the factory bios and then upload and start the machine. Can anyone help with this? Or perhaps a functional flash that can start the bios in the default position on the machine (jumper or short-circuit cmos deletion reset). Of course, for the motherboard in question.Comment
by samet4434SR1SJ (Intel Mobile Celeron N2815) - CPU
IO: İT8528E
MOTHERBOARD-CODE : ETON ET866 94V-0 E213441 Upper V1.02
5000-0004-0202
2013.1014.1400
BOTTOM CASE CODE: CASPER NIRVANA NB 14 MODEL: CLA
I need BIOS THANK YOU-
Channel: BIOS Requests ONLY!
Hi to all. Im searching for a laptop motherboard: ETON ET866 94V-0 E213441 Top V1.02 5000-0004-0202 schematics
Thanks very much!!!
Channel: Schematic Requests ONLY!
by BOSCHNJAKI am looking for programming software for board ETON.ET866 1302.2Z2. This PCB is built into the Switching Power Supply from ACBEL model FSA011 and I need information on how to program that PCB, On the board there is a small connector with 5 pins.
I need a programmer or emulator to access this board and adjust the voltage from 12.2 volt DC to 13.8 volt DC.
Can anyone help? Pictures attached.3 Photos -
by alegatorulhi,
i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....11-03-2024, 02:28 AM -
by dikmencasper CLA MODEL
ANAKART KODU:ETON ET866 94V-0 E213441 Top V1.02
EC ve MAİN bios-
- Loading...
