Optiplex 7080 Locked BIOS
  • elijahuff
    Nutze den Tag
    • Dec 2023
    • 10
    Hello my friends!
    I have a locked Optiplex 7080 BIOS that I would like to unlock.
    The problem is, I cannot find the BIOS/CMOS chip on my motherboard. I'm having a hard time finding it probably because of my age.
    Can someone help me out by explaining where is the BIOS/CMOS chip located in my Optiplex 7080?
    I tried to find it just by looking in the board but I couldn't find it.
    The computer is a Dell Optiplex 7080 and I believe the motherboard model is E93839.
    Danke!​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12414
    Originally posted by elijahuff
    Hello my friends!
    Danke!
    You have :
    64 ---> 8MB
    128 ---> 16MB
    256 ---> 32MB
    512 ---> 64MB
    For example : 25Q128BV... gives you 16 MB bios
    • elijahuff
      Nutze den Tag
      • Dec 2023
      • 10
      Originally posted by hoaca388
      You have :
      64 ---> 8MB
      128 ---> 16MB
      256 ---> 32MB
      512 ---> 64MB
      Hey! Thanks for your reply. This is the only thing that looks like a BIOS chip to me.
      But the problem is, it has 16 pins and not 8... What tool should I use/purchase to extract the chip data?
      Can you guide me a little?
      Danke!
      • hoaca388
        Badcaps
        • Jan 2022
        • 12414
        Danke!
        Use 16pin clamp.
        • Gcs_rma
          Banned
          • Dec 2023
          • 108
          • N/A
          QUOTE=elijahuff;n3170156]
          Danke![/QUOTE]
          you try Sop16 To Dip8 Adapter 300mil Socket Ic
          • elijahuff
            Nutze den Tag
            • Dec 2023
            • 10
            I cannot use this because the chip is welded to the mother board. Is there a clamp kit that I could use?
            I apologize, I'm still a rookie, I'm trying to understand how these things works.
            Danke!
            • elijahuff
              Nutze den Tag
              • Dec 2023
              • 10
              Will I need a 1.8v adapter to extract data from this chip? Does anyone know?
              Danke!
              • Gcs_rma
                Banned
                • Dec 2023
                • 108
                • N/A
                Danke!
                no. this chip bios is run 3.3v
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12414
                  Danke!
                  As far as I know, your chip has a voltage of 3v-> 3.6v
                  • elijahuff
                    Nutze den Tag
                    • Dec 2023
                    • 10
                    Great! So tomorrow I'll find a 3.3v CH341A EPROM to start testing!
                    If I upload my locked BIOS dump here, will you help me by changing it to be unlocked so I can flash it to the chip?
                    Danke!
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12414
                      Danke!
                      Be careful, CH341A (black board) has a default voltage of 5v, you must mod it down to 3.3v.
                      • elijahuff
                        Nutze den Tag
                        • Dec 2023
                        • 10
                        Thanks for the tip mein freund!
                        • elijahuff
                          Nutze den Tag
                          • Dec 2023
                          • 10
                          Does anyone know what do I need to do to set this CH341A to work under 3.3V?
                          I think it has to do with the jumpers, but I can't figure it out anywhere.
                          Danke in advance!
                        • elijahuff
                          Nutze den Tag
                          • Dec 2023
                          • 10
                          Can someone unlock this dump for me? I think I got the file correctly from the chip.
                          Dell Optiplex 7080
                          Edit: Just added a newer file which seems more complete.
                          Danke
                          • Maggiore
                            • Sep 2021
                            • 27
                            • Ukraine
                            Hi, Try
                            • elijahuff
                              Nutze den Tag
                              • Dec 2023
                              • 10
                              Originally posted by Maggiore
                              Hi, Try
                              Hello. Thanks for the file, but I don't think it worked.
                              After flashing the chip, when I power on the machine the LED blinks orange 3 times, then white 4 times.
                              No image is displayed.
                              Are you sure the changes you made to the file are correct? Because I only see two small differences between the original and the file you sent me.
                              Edit: Also I found ths:
                              Click image for larger version  Name:	image.png Views:	0 Size:	25.6 KB ID:	3172728
                              Danke!
                              • hoaca388
                                hoaca388 commented
                                Editing a comment
                                Servicer tag number ?
                              • elijahuff
                                elijahuff commented
                                Editing a comment
                                Service tag: 85VQ0D3
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12414
                              OptiPlex 7080 Small Form Factor
                              • elijahuff
                                elijahuff commented
                                Editing a comment
                                Thanks for uploading the files.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12414
                              This is a new file, you must try both.
                              • elijahuff
                                elijahuff commented
                                Editing a comment
                                Hi! I flashed both files, none of them worked unfortunately.
                                Danke!
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12414
                              You can flash the original file to see if it works.
                              • Derek Elliott
                                • Jan 2024
                                Did you ever solve your problem? I am in the exact same boat as you with the optiplex 7080
                                  DELL OptiPlex 7080 OptiPlex 7000 i5-10500T Specification for Upgrade or Repair
                                  This specification for the DELL OptiPlex 7080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7080 boardview and OptiPlex 7080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                  09-12-2024, 03:44 PM
                                  DELL OptiPlex 7080 OptiPlex 7000 i5-10500 Specification for Upgrade or Repair
                                  DELL OptiPlex 7080 OptiPlex 7000 i7-10700 Specification for Upgrade or Repair
