Need BIOS Dump/ROM for Lenovo Thinkstation p500
  • AHmad_Salal
    • Nov 2023
    • 11
    • Pakistan
    Hello all,
    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful.
    Here are the details of my machine (Lenovo Thinkstation P500)
    Processor: Intel Xeon E5-1650v3
    RAM: 2x8GB DDR4 2133MHz
    GPU: AMD R7 250 1GB
    Machine Type: 30A6
    S/N: PC0APW73
    Motherboard: Lenovo Scorpius rev. 1.0
    BIOS Version: A4KTACA​
    • 22424
    Originally posted by AHmad_Salal
    Hello all,
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    https://www.badcaps.net/forum/troubl...before-posting .
    You MUST:
    • AHmad_Salal
      • Nov 2023
      • 11
      • Pakistan
      Originally posted by SMDFlea
      [*]Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
      GPU: AMD R7 250 1GB
      Machine Type: 30A6
      S/N: PC0APW73
      • hoaca388
        Badcaps
        • Jan 2022
        • 12521
        Backup bios file ?
        • AHmad_Salal
          • Nov 2023
          • 11
          • Pakistan
          Originally posted by hoaca388
          Backup bios file ?
          I don't have the backup bios file but I tried reading the bios chip using CH431 mini programmer, not sure if was a good read or not so I did it twice. Dumps attached (could not upload .bin so uploaded .zip containing two dumps).
          P. S. Suspected bios chip located (please confirm by looking into the dump contents), It's a MX25L12873F
          • AHmad_Salal
            • Nov 2023
            • 11
            • Pakistan
            Is there a way to reset/change the bios settings to default in the bios dump file and re-flash the dump with changed settings? Will it work?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12521
              CCC
              • AHmad_Salal
                AHmad_Salal commented
                Editing a comment
                hoaca, please upload the correct file.
            • AHmad_Salal
              • Nov 2023
              • 11
              • Pakistan
              CCC
              Can't interpret what you are trying to say and what to do with this file (I am newbie in the bios field)?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12521
                https://www.badcaps.net/forum/troubl...21#post1622421
                • AHmad_Salal
                  • Nov 2023
                  • 11
                  • Pakistan
                  Is there a problem with my dump? I already went through this page
                    • 22424
                    CCC
                    something wrong there hoaca , 12.5KB compressed
                    • AHmad_Salal
                      • Nov 2023
                      • 11
                      • Pakistan
                      I think it's some kind of script, I opened it with notepad and it looks like a script to me
                      • AHmad_Salal
                        • Nov 2023
                        • 11
                        • Pakistan
                        I tried reading the bios chip again today (file attached) and guess what? The MD5 sums of this file doesn't match with the previous dump that I created yesterday and it is quite confusing for me. Am I not installing the adapter clip correctly or have the contents of chip changed overnight?
                        P.S. CR2032 coin cell battery is not installed in the motherboard.
                        • Maxpower3
                          Maxpower3 commented
                          Editing a comment
                          bios changes each time you reboot or change settings. do not use the clip is the best solution
                        • AHmad_Salal
                          Editing a comment
                          Comparison attached in my next post (#14).
                      • AHmad_Salal
                        • Nov 2023
                        • 11
                        • Pakistan
                        I tried comparing the both files and found out that some entries in Intel Image-->ME region-->MDES have changed (images attached). Is this normal?
                        P.S. MDES is ME debug event service.
                        • AHmad_Salal
                          • Nov 2023
                          • 11
                          • Pakistan
                          How can I reset the setting that I made in the BIOS in this dump, I think I need to clear the NVRAM but I don't know how to. Can someone guide me on how to clear the NVRAM in a Lenovo BIOS?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12521
                            My mind is not stable these days.
                            • zaheer118
                              • Feb 2016
                              • 14
                              • pakistan
                              hello hoaca388 is this file working ok ??????
                              if not ok please build my old file
                              no display machine power of after 1minut
                            • AHmad_Salal
                              • Nov 2023
                              • 11
                              • Pakistan
                              Sorry for the late reply but I ended up replacing the NVRAM region of my BIOS dump from a fresh BIOS, re-flashed it and it worked. Thank you everyone, a special thanks to hoaca388.
                              • zaheer118
                                • Feb 2016
                                • 14
                                • pakistan
                                lenovo thinkstation p510
                                s/n pc0qryq7
                                mt-m 30b4-sourop
                                mother board scorpius rev 1.1
                                old file attach
                                MX25L12873F_20240201_2342 old.​
                                  • 22424
                                  s/n pc0qryq7
                                  mt-m 30b4-sourop
                                  old file attach
                                  Off Topic, this thread is for the P500 .Post your request in the P510 thread -> https://www.badcaps.net/forum/troubl...tion-p510-bios
                                    LENOVO ThinkStation ThinkStation D20 (415522G), UK ThinkStation D E5520 Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkStation ThinkStation D20 (415522G), UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415522G), UK boardview and ThinkStation ThinkStation D20 (415522G), UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 03:36 PM
                                    LENOVO ThinkStation ThinkStation D20 (415518G), UK ThinkStation D E5520 Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkStation ThinkStation D20 (415518G), UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415518G), UK boardview and ThinkStation ThinkStation D20 (415518G), UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    LENOVO ThinkStation ThinkStation S20 ThinkStation S E5530 Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkStation ThinkStation S20 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation S20 boardview and ThinkStation ThinkStation S20 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    LENOVO ThinkStation ThinkStation S30 ThinkStation E5-1620 Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkStation ThinkStation S30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation S30 boardview and ThinkStation ThinkStation S30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    LENOVO ThinkStation ThinkStation D20 (415521G), DE ThinkStation D E5506 Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkStation ThinkStation D20 (415521G), DE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415521G), DE boardview and ThinkStation ThinkStation D20 (415521G), DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
