Gigabyte ga-j1900n-fffd2ph rev 1.1
  • mactouch
    • Nov 2018
    • 86
    • abudhabi
    need working bios please
  • hoaca388
    Badcaps
    • Jan 2022
    • 11813
    Re: Gigabyte ga-j1900n-fffd2ph rev 1.1
    Post the serial number, this is an update to the forum rules.
    • rex98
      • Feb 2023
      • 1280
      • Mandaue CEBU, Philippines
      use that
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • al3m0di
        Update bios EFCN58WW to EFCN59WW
        by al3m0di
        Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
        I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
        The BIOS version is EFCN58WW.
        When I turn on the device, it displays the message:
        "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
        The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
        I've tried
        07-29-2024, 10:32 AM
      • dl1nn1u
        Looking for a working BIOS for GIGABYTE G5 KD laptop motherboard NH50HPMB-0D
        by dl1nn1u
        There are also markings on the motherboard
        6-71-N5HP0-D04
        SN/ 1TNH50HP000003054018
        P/N 6-77-NH50HP00-D04-5C#1GB1
        The problem is as follows
        The laptop turns on, there is no image or backlight, after a minute the fans turn on, there is no old BIOS dump, please help​...
        04-30-2024, 08:40 AM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
      • trix11
        Dell Precision T1650 MT Workstation bricked after BIOS update
        by trix11
        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
        - Dell Precision T1650 mid tower Workstation
        - Xeon E3-1225 V2
        - 32Gb PC3-12800E RAM
        - 4Tb SATA HDD
        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
        I see now that others have experienced like issues e.g.:
        - https://www.dell.com/community/Prec...
        10-24-2022, 10:35 PM
