Socket A schematics - any board with VIA chipset (KT400A if possible)
  • N²x²N
    • Apr 2023
    • 54
    • Italy
    I can't find schematics for any socket A motherboard, probably my mistake in search terms.
    I'm troubleshooting a KT400A based board and would like to try something but I have no schematics to at least give it an attempt.
    Most important is the power on schematic.
    We try until we throw the towel.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Rezendes
    Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
    by Rezendes
    Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
    I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
    The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
    05-10-2024, 02:18 PM
  • DynaxSC
    ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
    by DynaxSC
    I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
    Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
    Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
    The behaviour is also really very strange, i.e.:
    • The disk shows always up in BIOS - so it is recognized, so far so good
    • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
    02-23-2025, 01:33 PM
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • DynaxSC
    ASUS STRIX Z490-F GAMING - No POST, stubborn board
    by DynaxSC
    I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
    The situation looks like this:
    After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
    1. RTC oscillates normally (32.768KHz).
    07-08-2022, 05:45 AM
