B550 AUROS MASTER REV 1.0 schematic & boardview please
  • rex98
    • Feb 2023
    • 1293
    • Mandaue CEBU, Philippines
    Does anyone have boardview or schematic of GIGABYTE B550 AUROS MASTER REV 1.0?
    I badly needed it. Ty in advance
  • rex98
    • Feb 2023
    • 1293
    Re: B550 AUROS MASTER REV 1.0 schematic & boardview please
    so guys it so happen that i solved my own problem finding boardview and schematic i find it online. so just wanna share here maybe someone also need this.
    • digtalhd
      Gigabyte Z590 Aorus Master Schematic and BoardView need
      by digtalhd
      Hi everyone, I need help and schematic and boardviuw of Gigabyte Z590 AORUS Master boards.
      Thank you for your help.
      12-30-2024, 09:24 AM
    • Ovi91
      Auros B450 M motherboard Schematic & Boardview
      by Ovi91
      Hi I need a schematic or a picture to find the missing part from the motherboard.I attach a picture with missing parts. Is between the memory slot and 24 pin connector.Thanks and I hope someone has at least motherboard and be able to take a picture..
      01-25-2024, 07:27 PM
    • PacoGT
      HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
      by PacoGT
      hello firends
      i search the schematic or boardview
      I have this motherboard, but I can't find the schematic or the boardview.
      The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
      So the computer doesn't turn on, and the 3V disappears after a few seconds.
      The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
      The new problem arose after removing the bad chip.
      3V and 5V remained together,...
      08-19-2025, 08:25 PM
    • hosain0489
      Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
      by hosain0489
      I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
      Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
      If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
      Thank you very much in advance!
      07-15-2025, 11:20 AM
    • re-atari
      Gigabyte GA-H110-D3A schematic/boardview needed
      by re-atari
      Hello all,
      Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
      This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
      02-24-2025, 06:45 PM
