Help HP Elitedesk 800 G6 Mini PC LOCKED BIOS
  • peste
    • 13904
    • ROMANIA
    Re: Help HP Elitedesk 800 G6 Mini PC LOCKED BIOS
    Originally posted by skypc86
    hello, can someone help me and remove the bios password?
    try..
      • 22241
      You must post the serial number,as per the rules.
      https://www.badcaps.net/forum/showthread.php?t=103569
      • RecklessMaker
        • May 2024
        Recently picked up an HP EliteDesk 800 G6 (Product 3E2E2US, Serial MXL1093CPH, Motherboard DA0F93MB6F0 Rev F) at Goodwill but the BIOS was locked. I desoldered and dumped both the BIOS chip (GD25B256D) and the EC chip (MX25L12873F) on my TL866II+. I ran the EC image through RCunlocker (it said it succeeded) and reflashed the EC chip. I also cleaned the ME Region of the BIOS using the guide from Level1Techs.
        Unfortunately the machine no longer POSTs. The fan comes on at full speed as soon as I plug the machine in, then eventually ramps down, but that's it. No beep or flash codes at all. If I remove the EC chip, it does give the correct beep & flash codes, so it seems like the motherboard is ok. I've tried every combination of modified and original binaries for both chips; no change. I tried recovering the BIOS via a USB flash drive, but the machine doesn't even try to read the drive. I was unable to extract BIOS or EC binaries from the update executable (does not have the 'Copy' option). I found a couple of other threads for the Elitedesk 800 G6, but I don't know whether the EC or BIOS files in those can be used with my machine.
        What did I do wrong? What do I do now?
          SMDFlea commented
          Editing a comment
          Thread merged.
      • rex98
        • Feb 2023
        • 1297
        • Mandaue CEBU, Philippines
        flash both
        • RecklessMaker
          • May 2024
          Originally posted by Rexer Anthony
          flash both
          No change
          I think the BIOS may be corrupted. Either that or I killed the motherboard somehow. When I try to boot without the EC chip, I no longer get a beep code.
          • macmino
            macmino
            • Aug 2024
            • 13
            • Italy
            #26
            hi, I'm in a rabbit hole: I have the "OK" from the RCUnlocker_v_1_0 and so I loaded the 16MB "800G6_EC_RCunlocked_unlocked.BIN" inside the NeoProgrammer 2.2.0.10. If I click "Detect" I only see:
            Code:
            Connecting Error CH341 (Not found)
            IC not responding
            I'm running Windows 11 directly on top of the HP Elitedesk G6 800, do I have to desolder ?
            what can I do now?
            Thank you !!!!!
            • macmino
              macmino
              • Aug 2024
              • 13
              • Italy
              #27
              sorry, cross posted after searching other informations...I'm waiting for the USB programmer, and so tomorrow I should dump/flash it back and keep you posted. Thanks again...and BTW, ehy, the post now is on top
              cheers
              • macmino
                macmino
                • Aug 2024
                • 13
                • Italy
                #28
                Ok, now the programmer has arrived and I did probably some mistakes because now I see the message "HP Endpoint Security Controller Problem: There is a problem with the HP Endpoint Security Controller on the unit, please contact HP Inc to have the unit serviced"
                what can I do now?
                thanks
                • macmino
                  macmino
                  • Aug 2024
                  • 13
                  • Italy
                  #29
                  a little progress here: I finally received the programmer but when I connect it to the motherboard, I receive this message:
                  Code:
                  [B]IC Not Responding[/B]
                  only once I got the message
                  File size larger than IC size
                  while using the ASprogrammer 2.1.0.13...I was able to read but not to write
                  any idea? thanks a lot !
Name:	Screenshot 2024-08-29 at 17.53.11.png
                  ps: the current is 3.3, just checked it out
                  • macmino
                    macmino
                    • Aug 2024
                    • 13
                    • Italy
                    #30
                    well, I bought different cables and now I successfully dumped the old bios, so it was just a cable and connector stuff. If I put the file into the RCUnlocker it says: "Missing unlockable Content"
                    I noticed that during the writing of the Unlocked Image (fond in this forum) I received an alert from the Programmer saying it has hit an error, so I clicked continue and the Programmer stuck.
                    BTW now I successfully installed the new unlocked version! hooray!!! The HP now give me the ability to enter into the BIOS and Security settings but I have a message at the beginning: "HP Endpoint Security Controller Problem"....even if I update the BIOS from the Windows itself (and all the HPs software) I'm not able to remove this message..I simply hit ok and then the boot continues. What can I do now? I THANK YOU !!!
                      • 22241
                      Enable secure boot if its not already enabled.
                      • macmino
                        macmino
                        • Aug 2024
                        • 13
                        • Italy
                        #32
                        I tried to enable and disable it, no success
                          • 22241
                          Did you make a backup of the original bios. Which bios did you flash,from which post ?
                          • macmino
                            macmino
                            • Aug 2024
                            • 13
                            • Italy
                            #34
                            the issue is that. I'm facing a lot of issue with the micro clamp connector: the yellow led "RUN" on the usb key sometime disappear completely while I'm dumping. Probably I have to change clamp and use another method
                            • Al3xxxinho
                              • Jul 2017
                              #35
                              I need some help as I believe I may have made a mistake.
                              I have an HP 800 G6 DM, and I desoldered the EC chip from the motherboard (GigaDevice 25B127DSIG). Using NeoProgrammer, I dumped the ROM and then attempted to unlock it with RC Unlocker. However, after flashing the unlocked file back, the password was still present.
                              Because I am an idiot, I flashed an unlocked firmware from this page back to the chip and after doing so, my computer won't boot anymore - it shows an error pattern of 5 red blinks and 2 white blinks.
                              Even after restoring the original dump, the issue persists with the same 5 red and 2 white blinks.
                              I've attached both the original and unlocked files for reference.
                              Thank you for your help!
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12433
                                #36
                                Look around the bios chip there are very small components, do you accidentally move them ?
                                ​https://www.badcaps.net/donate
                                • Al3xxxinho
                                  • Jul 2017
                                  #37
                                  I've looked around the chip and all is fine. I do have soldering experience so that shouldn't be an issue. I will desolder the chip again today and have a better look.
                                  After desoldering I erased the chip and used the below file to flash it
                                  In ASProgramer I've selected GD25Q127C
                                  After resoldering the chip, the led error is gone, computer powers up, fans are spinning but no image is displayed.
                                  Later edit: After leaving it on for a while, the image was displayed. Now bios is unlocked, the only error I am getting is related to HP Enpoint Security,
                                  • Al3xxxinho
                                    • Jul 2017
                                    #38
                                    I had 2 desktops with a locked bios. I desoldered the chip from the 2nd unit, dumped the bios, verified the dump and then used RC Unlocked V1_0 to fix the dump.
                                    After writing the dump to the chip and resoldering it I get the same LED sequence on the 2nd unit. Seems like my RC_Unlocker is corrupting the files somehow.
                                    Can anyone help me unlock the attached files?
                                    Thanks!
                                      • 22241
                                      Thanks!
                                      post the serial numbers https://www.badcaps.net/forum/troubl...30#post1847530
                                      • Al3xxxinho
                                        • Jul 2017
                                        #40
                                        Sorry, I have written the S/N below:
                                        - dump.bin - SN: 8cc1070m6w
                                        - hp_bin.bin - SN: 8cc1291gnt
