Acer chromebox CX14
  • jhefcruze
    • Mar 2017
    • 31
    • manila
    #41
    Re: Acer chromebox CX14
    unlock this pls
    and send me other side to donate maybe not pay pal where not using always pay pal
    thanks advance
      • 20967
      Originally posted by jhefcruze
      unlock this pls
      thanks advance
      The Admin only accepts paypal donations at the moment. Try again later, if you ca`nt its no problem at least you tried.The Admin is always happy to receive a thank you message
      • jhefcruze
        • Mar 2017
        • 31
        • manila
        #43
        i try now morning but no luck
        • jhefcruze
          • Mar 2017
          • 31
          • manila
          #44
          acer CXi4 built EMMC chromebox
          unlock this pls built in EMMC
          thanks advance
          • volinakis
            • Jan 2021
            • 2734
            • N/A
            #45
            Re: acer CXi4 built EMMC chromebox
            thanks advance
            reinstall from USB stick made for your model with Chromebook Recovery Utility after write new bios.
            • jhefcruze
              • Mar 2017
              • 31
              • manila
              #46
              you are greatemaster thank you
              i try manual HxD editor master i
              enable dev mode and disable enrollment
              but i can't install recovery
              i compare the 2 BIOS
              UNLOCK YOU GIVE AND LOCK BIN
              HOW CAN I MAKE IT RUN TO OTHER UNIT
              THANKS YOU
              • volinakis
                • Jan 2021
                • 2734
                • N/A
                #47
                THANKS YOU
                compare again, there are 6 modifications ... Create USB disk as indicated and insert it in USB port then power on laptop, it will start recovery itself.
                • jhefcruze
                  • Mar 2017
                  • 31
                  • manila
                  #48
                  i try to edit mater but i try same model
                  so many different may i be need a clear dump file for cxi4 i extract the ME in other working
                  bin you send but if i copy your bin to other not display and restart pc
                  how to edit so i cant make my own help me pls thanks advance master
                  • volinakis
                    • Jan 2021
                    • 2734
                    • N/A
                    #49
                    dosn't work that way, you have to modify each bios.
                    • jhefcruze
                      • Mar 2017
                      • 31
                      • manila
                      #50
                      how can i modify that master any need tools software editor
                      thanks
                      • jhefcruze
                        • Mar 2017
                        • 31
                        • manila
                        #51
                        unlock this pls thanks
                        • volinakis
                          • Jan 2021
                          • 2734
                          • N/A
                          #52
                          reinstall as you made with 1st one. If you want to LEARN (and not doing something mechanical) how to deprovision a chromebook there are a lot of threads in this great forum about this, you just have to read them. This is how I learned.
                          • jhefcruze
                            • Mar 2017
                            • 31
                            • manila
                            #53
                            thank you very much master i want to learn more about bios editing chrome book unlock and remove google account i reading now i enable and disable dev mode and enrollment in manual by editing HxD i want to learn more i cant make new bin just like you doing
                            im willing to donate every file i send here but i can't send here in pay pal to save dis forum is great for all technician thanks admin
                            • jhefcruze
                              • Mar 2017
                              • 31
                              • manila
                              #54
                              this is the cxi4 2nd that you give i compare to stock bin
                              you make 6 different how ? only
                              but if i compare the unlock you give to other unit but same model lock there's more different hehe challenging i want to do it give me some tips master hehe
                              im searching i want to make this so i cant help to other tech newbies
                              thanks advance
                              • smallvhin
                                • Jul 2015
                                • 182
                                • philippines
                                #55
                                master pls. unlock google account TIA🙏
                                • smallvhin
                                  • Jul 2015
                                  • 182
                                  • philippines
                                  #56
                                  Thanks master veterans
                                  • jhefcruze
                                    • Mar 2017
                                    • 31
                                    • manila
                                    #57
                                    thanks you master i got it
                                    i want to learn now how to make new bin if i lost bin file or if the files is lost or did not save
                                    how make new one
                                    thanks
                                    • jhefcruze
                                      • Mar 2017
                                      • 31
                                      • manila
                                      #58
                                      try this master if working
                                      • smallvhin
                                        • Jul 2015
                                        • 182
                                        • philippines
                                        #59
                                        more tanks master
                                        • volinakis
                                          • Jan 2021
                                          • 2734
                                          • N/A
                                          #60
                                          thanks advance
                                          you have to compare original .bin file against modified .bin file for THE SAME LAPTOP!
                                            Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) Spin 513 Specification for Upgrade or Repair
                                            This specification for the Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Enterprise Spin 513 R841T boardview and Acer Chromebook Enterprise Spin 513 R841T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-07-2024, 01:30 AM
                                            HP Chromebox Enterprise G2 Chromebox i5-7200U Specification for Upgrade or Repair
                                            This specification for the HP Chromebox Enterprise G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Chromebox Enterprise G2 boardview and Chromebox Enterprise G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 02:00 PM
                                            ACER Chromebox CXI3 Chromebox i3-8130U Specification for Upgrade or Repair
                                            This specification for the ACER Chromebox CXI3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Chromebox CXI3 boardview and Chromebox CXI3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                            09-12-2024, 03:30 PM
                                            ACER Chromebox CXI3 Chromebox 3867U Specification for Upgrade or Repair
