Sapphire Pulse RX580, wrong voltages on GS7103
  • bogosort
    • May 2022
    • 78
    Hello, I get these voltages on the GS7103. I'm not sure where to go from there. Should I just replace it?
  • harp
    • Jun 2022
    • 650
    • Planet Earth
    Re: Sapphire Pulse RX580, wrong voltages on GS7103
    Why you measure this pins, how to get to do so?
    Teach us
    On pin #2 is missing enable, for some reason...
    • bogosort
      • May 2022
      • 78
      Teach us
      I figured it out. Thank you!
      • Nahcetox
        RX580 Sapphire Pulse 8GB – I need auxiliary BIOS
        by Nahcetox
        Hello everyone, I need some help with a Sapphire RX580 Pulse 8GB.
        The support BIOS (the small auxiliary one on the card) got burned/damaged, and I’m looking for the correct BIN file to reprogram it.
        The chip is a Pm25LQ020.
        Since this is an auxiliary/support BIOS, the standard GPU BIOS file won’t work.
        If anyone with a working card could please share a dump of this chip, I would be very grateful.
        Thanks in advance!
        12-07-2025, 10:32 PM
      • mengpo
        Need help to repair a RX580 Sapphire Pulse
        by mengpo
        I've got a rx580 Sapphire Pulse stopped working while I was playing a game.
        Since then, when I turn on my computer, the fans are spinning but the card is not recognized (no display neither). The GPU core is heating when turned on. I'm a noob in electronic and I followed some youtube stuff but no luck for now.
        I wrote down what I found (see the pictures) and I got a strange behavior on the APW8722A, on the top left. The VCC pin (the 5th) has 0V and 0 Ohm when the card is powered up.
        According to the APW8722A datasheet, from a second APW8722A...
        01-06-2022, 03:24 PM
      • timekn
        Please help! i need boardview for Asus DUAL-RX580-O8G and Sapphire PULSE RX 580 8G G5
        by timekn
        Hi, I would need a boardview of the pulse rx580, because im missing some components.
        On ASUS RX580 I have a problem with the power connector, because the GNDs are missing. I'm a re-solder, I changed the connector with a new one and the problem is still the same. When I start the gpu my computer shuts down.
        I tested the 12V power rails on the PCE-I and there is no short circuit, i also checked a 3.3V rail and the problem remained the same, no short circuit. Would it be possible to get a boardview of the GPU to check if all components are in their place. I greatly appreciate the help!...
        02-09-2022, 11:58 AM
      • tls 123
        What is this component? RX570 4GB SAPPHIRE PULSE
        by tls 123
        Hello! I am a newbie and I'd like to ask for your help regarding a certain part in my RX570 4gb Sapphire Pulse... I had it diagnosed and the two technicians said that the cause of my bad gpu (shorted) is because of this certain component which they have no reserve for. I have the option to find a donor board that I can bring to them or buy a new component and have them replace it, I tried to search for the component but I cant quite find it... some text is written AEAH 037. Please, and thank you for helping!...
        01-04-2025, 04:53 AM
