Asus 1660s dual need image
  • Ros2468
    • Feb 2022
    • 16
    • Norway
    I have this 1660s where there is some capacitors torn of underneat the memory modules - could anyone get me a closeup image of this capacitor because i cannot confirm if both veils is connected or one.
    https://drive.google.com/file/d/1_HU...w?usp=drivesdk
  • dj_ricoh
    • 2073
    • uk
    Re: Asus 1660s dual need image
    do you have a boardview? or schematic?
    considering the distance its similar on the pad i can assume is the same value like the one on top. esr meter will confirm the capacity and if you power the card you can probe the pads and see if every cap nearby has the same voltage.
    • Ros2468
      • Feb 2022
      • 16
      • Norway
      I would like to have boardview file for this!
      The problem is that my optics does not have enough "x" to get a clear image of these traces.
      The solder pad in the image is partly loose and might be overlapping another trace
