Msi gtx 1060
  • didi79
    • May 2021
    • 80
    • BE
    Msi gtx 1060
    I'm diagnosing a MSI GTX 1060 AERO ITX 3G OC.
    No shorts. When powered all voltages are there, cpu is getting hot. But PC does not detect te card and obviously no image output.
    PCB is in real good condition, visual inspection gives no clues: no missing caps on the PCI-E lanes, no coloration on the chip. Resistance on the PCI-E lanes is good. So I'm assuming the chip is fine.
    I also see no signs of previous repair attempts.
    Not sure now what else the problem could be. Any ideas what to check next ?
    • 22427
    Re: Msi gtx 1060
    Have you checked pin 11 reset plus the AND gate voltage (assuming there is an AND gate)
    • didi79
      • May 2021
      • 80
      • BE
      Re: Msi gtx 1060
      Good tip. It should be high when powered, correct ?
        • 22427
        Re: Msi gtx 1060
        Yes.The AND gate will have 2 inputs and 1 output usually.
        • didi79
          • May 2021
          • 80
          • BE
          Re: Msi gtx 1060
          schematic is this one: https://www.badcaps.net/forum/showth...60#post1063932
          Page 3 and 36 show there is only one 0 ohm resistor between the slot and the chip.
          When powered, I have 3.3V on PEX_RST (on both sides of the resistor, that seems correct.
          One last thing I'll check is wether I can read the BIOS. After that, I can't think of anything else :/
          • didi79
            • May 2021
            • 80
            • BE
            Re: Msi gtx 1060
            Hm, whenever I clamp my USB CH314 programmer on the BIOS, the programmer disappears from device manager. If I remove the clamp, it's back.
            This could indicate a short in (or near) the BIOS chip, in fact shorting the programmer (and shutting it down).
            I happen to have a donor board with exactly the same BIOS chip. I can read that one out just fine, so the problem is not the programmer.
            I know what to try next ;-)
            • zefrench
              • Feb 2022
              • 27
              Re: Msi gtx 1060
              What bios programmer do you use ?
              • didi79
                • May 2021
                • 80
                • BE
                Re: Msi gtx 1060
                cheap USB programmer (that type https://www.banggood.com/CH341A-24-2...650183533.5781) with voltmod. Has been working great so far.
                As for the software: AsProgrammer
                • didi79
                  • May 2021
                  • 80
                  • BE
                  Re: Msi gtx 1060
                  I desoldered the BIOS. I hooked it up to the programmer and I was able to read it.
                  The BIOS chip sits right next to the 1.8 VRM. In fact the only thing between the BIOS Vin and the 1.8V buck converter (RT7296) is a coil.
                  Remember: I have 1.8V and all other voltages, yes even VCore and VMem. But when I measure resistance between GND and 1.8V it reads only about 0.5 ohm (multimeter minimum is 0.1 ohm) or almost short. That does not make sense to me. If it were a short, I would probably not be able to measure the 1.8V.
                  I guess that (almost) short is what made the BIOS unreadable when on the PCB (it shorted the programmer out). And the short is definitely not in the BIOS.
                  Again, I don't know where to go from here
                  • didi79
                    • May 2021
                    • 80
                    • BE
                    Re: Msi gtx 1060
                    Little help?
                    I have 1.8V on the coil where the red arrow points to. The LDO generating it is to the right of the coil.
                    Notice the BIOS chip is desoldered to the left of the coil.
                    From the coil to ground, I have about 1 ohm resistance. GPUs usually have very low resistance... coincidence or not?
                    If I inject a low (safe) voltage on the coil, the only thing that gets slightly warm after a while is the GPU itself (front, not back of pcb).
                    Is it normal for cards like these to have 1.8V going directly to the chip?
                    • supertype
                      • May 2013
                      • 14
                      Re: Msi gtx 1060
                      Bios runs on 1.8v
                      on the programmer use a meter and measure pin 1 voltage make sure its not dumping 5v or 3.3 on the chip it needs 1.8 or you could damage the bios.
                      I had someone point this out to me on a card I am working on and had to get a daughter board to drop the voltage down because I was damaging the chips when inspecting them and write/read.
                      • didi79
                        • May 2021
                        • 80
                        • BE
                        Re: Msi gtx 1060
                        Originally posted by supertype
                        Bios runs on 1.8v
                        Hey you're right. I actually totally ignored the fact that it's a 1.8V chip even tho I know it's on the 1.8V line and the datasheet clearly states it ). Then again when desoldered, I could actually read it (with my CH341-modded-to-3.3V-adapter). So while the chip probably can take a higher voltage, another component on the card may not.
                        Next investment: https://www.aliexpress.com/w/wholesa...v-adapter.html
                        • didi79
                          • May 2021
                          • 80
                          • BE
                          Re: Msi gtx 1060
                          Adapter is in. BIOS chip is readable, but I suspect some garbage content.
                          Now I have to find the BIOS dump... Techpowerup does not seem to have one for this particular model: https://www.techpowerup.com/vgabios/...ze=3072&since=
                          I'll try with a similar one (eg https://www.techpowerup.com/vgabios/...60-3072-161223) since the clocks pretty much seem the same and it also supports Samsung memory...
                            • 22427
                            Re: Msi gtx 1060
                            Found one on the MSI forums https://forum-en.msi.com/index.php?t...equest.301014/
                            • didi79
                              • May 2021
                              • 80
                              • BE
                              Re: Msi gtx 1060
                              Great find, thanks!
                              • didi79
                                • May 2021
                                • 80
                                • BE
                                Re: Msi gtx 1060
                                Still not detected. I will have a look wether the card actually tries to read the chip, using oscilloscope.
                                  Gigabyte AERO 14W-1060-BK7 Notebook Specification for Upgrade or Repair
                                  This specification for the Gigabyte AERO 14W-1060-BK7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14W-1060-BK7 boardview and 14W-1060-BK7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 05:46 AM
                                  Gigabyte Sabre 15-1060-803 Notebook Specification for Upgrade or Repair
                                  This specification for the Gigabyte Sabre 15-1060-803 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-1060-803 boardview and 15-1060-803 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 11:44 AM
                                  Gigabyte Sabre 17-1060-803 Notebook Specification for Upgrade or Repair
                                  This specification for the Gigabyte Sabre 17-1060-803 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17-1060-803 boardview and 17-1060-803 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  Gigabyte AERO 15-1060-BK81 Notebook Specification for Upgrade or Repair
                                  This specification for the Gigabyte AERO 15-1060-BK81 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-1060-BK81 boardview and 15-1060-BK81 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 06:42 AM
                                  Gigabyte AERO 14W-1060-OG7 Notebook Specification for Upgrade or Repair
                                  This specification for the Gigabyte AERO 14W-1060-OG7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14W-1060-OG7 boardview and 14W-1060-OG7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
