Can't recognized caps
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 332
    • D12
    Hi, can someone help me I have determine voltage on this cap on picture below. I have donor board and I would like to replace caps but I am not sure if they are same voltage. I see that they are both 270 ohm, but on this other one there is no voltage I google that C letter is for 16V mark, but I would like someone to confirm if thats true. And Would it be wise if we determine they are 16V to replace them all ? btw I know that one cap is missing and I noticed that on one board those 270 ohm caps are a bit shorter.
  • gt403cyl
    • Jan 2017
    • 35
    Re: Can't recognized caps
    The cap has a rating of 270uF (not ohms, that is resistors).
    As for voltage ratings, depends what part of the circuit it is located...
    The pic on the left, shows a 6.3v cap on the left of the heat spreader and a 2.5v cap on the right of it.
    I would think a 6.3v cap would be fine.
    However having the correct cap for a replacement would be ideal.
    Also voltage ratings on caps are generally the MAX voltage the cap is rated for, so using a 16v cap on a 6.3v circuit should be fine.
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 332
      • D12
      Sorry I wrote wrong I ment uF not ohms don't know what I was thinking...
      Ones on the left would replace those to the right. I forgot to say that left is donor board, and on the right is board I would like to repair.
      6.3V are caps beside that one I would take off, but not that I pointed red on the picture.
      • piernov
        • Jan 2016
        • 4435
        • France
        This is input decoupling of the CPU VCore VRM so this will obviously be rated at 16V at least. Put a 6.3V and you'll get some nice fireworks…
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 332
          • D12
          I know when people are talking rubbish don't worry
          I found board schematics for donor board and those caps are 16V, I guess that would be okay to replace all on that board I want to revive, right ?
          • gt403cyl
            • Jan 2017
            • 35
            Can you tell me if it's not a problem if those are 16V I found in manual of nippon caps that C is for 16V, but I'm not sure I need someone who is in electronics to confirm.
            I was under the impression it was the other way around, obviously putting a 6.3v rated cap in a 16v circuit is bad.
            If you would read my response you would see that. I even state that.
            • lotas
              • Jan 2016
              • 4599
              • Russia
              nichicon LF series
              C = 16v
              • Thermaltake
                Brain badcap
                • Aug 2015
                • 332
                • D12
                Originally posted by lotas
                nichicon LF series
                C = 16v
                Thanks. So it's safe to replace all three caps, right ?
                • lotas
                  • Jan 2016
                  • 4599
                  • Russia
                  Yes, replace all three, just observe the polarity of the capacitor on the board (ASUS has a non-standard polarity - with a white stripe it is positive).
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 332
                    • D12
                    Thanks!
                    For all info. As I see they both have negative polarity on the same side Asrock and Asus. White is negative.
                    • Thermaltake
                      Brain badcap
                      • Aug 2015
                      • 332
                      • D12
                      Caps soldered from donor board to one that I want to revive, everything is working fine
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
