GTX 760 not recogniced correctly
  • foshland
    • Jan 2017
    • 122
    • Spain
    Hi, that card in 3 diferent computers is only detected as a generic display driver, have nothing to do with drivers, post fine but not detected as a gtx, any clue? thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    Re: GTX 760 not recogniced correctly
    try MATS for memory damage
    • foshland
      • Jan 2017
      • 122
      • Spain
      Hi, finally it was a memmory fault as ktmmotocross said, thanks a lot.
      But the problem was a faulty capacitor near the memmory module that was giving errors, so no need to work on the module, just replace the capacitor
      Graphic card working again, thanks a lot
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3593
        • slovakia
        hpw u find that capacitor is bad?
        • foshland
          • Jan 2017
          • 122
          • Spain
          Hi, it looked discoloured, not same color as the ones in other memmories, checked with capacitance meter and changed to the value the other mems had and voila. Thanks KTM
          • DynaxSC
            • Apr 2021
            • 461
            • Poland
            That's really a creative diagnosis method, really would never come on it
            • foshland
              • Jan 2017
              • 122
              • Spain
              Well, I had a look in the directions where KTMmotocross told me, memmory problem, used MATS, it detected some (14K) faults, had a look with the microscope arround the faulty mem, saw a discolored capacitor and why not meassuring it???, looks like faulty? change it!!!, no heat aplied to the mem chip, so it seems to be just that capacitor out of range, now everything is running fine, detected as it is and GPU-Z tells its fine. Changed pads and thermal paste, runned furmark for an hour and still fine. Card is working and doing what it has to do, play games.
              Thanks to KTM user and all of the comunity
              • DynaxSC
                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                by DynaxSC
                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                The behaviour is also really very strange, i.e.:
                • The disk shows always up in BIOS - so it is recognized, so far so good
                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                02-23-2025, 01:33 PM
              • spacez
                XPS 15 9520 - tpm device is not detected - NO ssd detected
                by spacez
                I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
                Service Tag: J2MSHW3
                |Express Service Code: 41518077843
                mother board LA-L402P REV 1.0(A00)​...
                08-18-2024, 10:54 PM
              • Nikan.e
                Inno 3d RTX2070 not detected - no I²C connection
                by Nikan.e
                Greetings and Salutations!
                I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
                The faulty DrMOS was removed, and the burned PCB area was milled away.
                All voltages are now good, but the GPU is not being detected.
                I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
                I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
                I thought these pins were used for communication during startup?!?
                On all...
                03-30-2025, 07:21 AM
              • superdota2
                HP 15s-FQ2552TU nvme drive not detected
                by superdota2
                HP 15s-FQ2552TU
                da0p5hmb8f1 rev f
                sn# 5CD138CCH4
                problem is power on but no display,no bios post
                i search bios here ,i found and it work and got display.
                https://www.badcaps.net/forum/showthread.php?t=104925
                second problem is nvme drive not detected in bios intel rapid storage,
                i tried a working nvme drive but still not detected in bios,
                also tried install system and install intel rapid driver,still not detected....
                06-21-2023, 09:36 PM
              • Scotchmist
                Lenovo thinkpad 15 itl g2 - No Hdd detected
                by Scotchmist
                Hi
                I got this laptop with bad onboard ram so edited the bios with SPD removal tool to disable the onboard ram and work with the ram slot - the laptop now posted so i thought all was good however when i put everything back together it will not boot to windows as no boot device found., In the bios is says hdd not detected, i disabled VMD in the bios but still the same, loaded windows on usb stick and windows install cannot find the hdd. I bought a second board that had water spill, repaired the damaged area and it posted ok but same issue no hdd detected.
                I have now tried...
                09-11-2024, 05:06 AM
