good day and merry christmas!
Ihave this graph, gtx 780 direct cu 2 (gtx780-dc2oc-3gd5) The scheme is similar to Poseidon:
https://www.badcaps.net/forum/attach...0&d=1604596799
problem:
I did all the measurements and they all work, except for the 3.3v line.
I have a voltage drop of 0.07mV, or with a resistance of 2 ohms
Vcore and vram coils show acceptable values
I tested it on a board and the core and frame voltages are normal.
I am trying to follow the board review but it is difficult for me as it creates tension, as the video notes:
I have injected the following voltages and it consumes:
1v 11ma
1.5v 250ma
2.5v 500ma
2.9v 890ma
3.3v 390ma and short
https://drive.google.com/file/d/1pR8...ew?usp=sharing
when injected less than 3V, it does not produce a short circuit and, apparently, has a high consumption. I really don't know how much is the normal amount on this plate in that line.
On the other hand, if I inject more than 3V, a short circuit occurs.
I also took BIOS (u6), reprogrammed it and see if it's short, etc. but that doesn't work either
I found that this capacitor has a resistance between the poles of 0.06 ohms.
and the mass is the same. (c33)
That would be good?
I know there is a lot to ask for, but can you help me? Thanks!
problem:
1v 11ma
1.5v 250ma
2.5v 500ma
2.9v 890ma
That would be good?
