asus gtx 780 direct cu 3.3v ?
  • totto210
    • Apr 2021
    • 51
    • chaco
    good day and merry christmas!
    Ihave this graph, gtx 780 direct cu 2 (gtx780-dc2oc-3gd5) The scheme is similar to Poseidon:
    https://www.badcaps.net/forum/attach...0&d=1604596799
    problem:
    I did all the measurements and they all work, except for the 3.3v line.
    I have a voltage drop of 0.07mV, or with a resistance of 2 ohms
    Vcore and vram coils show acceptable values
    I tested it on a board and the core and frame voltages are normal.
    I am trying to follow the board review but it is difficult for me as it creates tension, as the video notes:
    I have injected the following voltages and it consumes:
    1v 11ma
    1.5v 250ma
    2.5v 500ma
    2.9v 890ma
    3.3v 390ma and short
    https://drive.google.com/file/d/1pR8...ew?usp=sharing
    when injected less than 3V, it does not produce a short circuit and, apparently, has a high consumption. I really don't know how much is the normal amount on this plate in that line.
    On the other hand, if I inject more than 3V, a short circuit occurs.
    I also took BIOS (u6), reprogrammed it and see if it's short, etc. but that doesn't work either
    I found that this capacitor has a resistance between the poles of 0.06 ohms.
    and the mass is the same. (c33)
    That would be good?
    I know there is a lot to ask for, but can you help me? Thanks!
  • foshland
    • Jan 2017
    • 122
    • Spain
    Re: asus gtx 780 direct cu 3.3v ?
    Hi, that is too low resistance on that capacitor, but first of all, when you say you inject more than 3V in that line.. How many volts do you inject?
    • totto210
      • Apr 2021
      • 51
      • chaco
      hi foshland. do you see the video?
      my psu is in : 1A max settings.
      1v 11ma
      1.5v 250ma
      2.5v 500ma
      2.9v 890ma
      now... i have raised the c33 and broken
      and i have measured that line of c33 and short persiste. really i dont know the value of that piece... boardview is incomplete
      • foshland
        • Jan 2017
        • 122
        • Spain
        Hi, I didnt see the video, now I did, first try to find the short and later we will try to find that capacitor value.
        Inject 3.3V limiting to more than 1A the PSU, but if you inject you will need to find what is getting hot, try with alcohol for example
        • totto210
          • Apr 2021
          • 51
          • chaco
          nothing hot my friend.. i already injected that
          my psu is 15v 2a only. i tried to inject 2a but consumes only 0,83a in 3.3v now---
          EDIT:
          i injected that voltaje-- consumes 0.80-0,90a in 3.3v
          I've kept it there for 1 or 2 minutes and it just starts to warm the gpu, barely.
          gpu dead?
