Hello, the GPU I'm trying to repair produces no signal, fans spin at 100% all the time and isn't recognized in Windows at all. All chokes have voltage, resistance from GPU power delivery to GND is at ~1.1 Ohm (1.7 on multimeter) so I guess it's OK. It recognizes no PCIE power plugs with its speaker. The weird thing is that the core hardly heats up - by that I mean that the MOSFETs on power delivery are hotter than core, but at the same time I can't feel any component burning hot. Previous owner told me that it had artifacts, so I feel like it might have been in oven or under hot air gun guessing by weird looking sticker right over PCIE connector. My random guess is that it has corrupted BIOS or dead GPU core. As I don't have an external programmer can I do anything to rule out one or the other?
8800 GTX no signal
Re: 8800 GTX no signal
Take meassures of other rails, 5V, 3.3 and so on. (Resistance to ground and voltages). Meassure bios chip voltage, look for its datashhet and look if its 1.8V or more. Start from that. Look for a temperature gun or something to meassure temperatures. The core heats first, then the memmory few seconds later. Look for shorts, test all the fuses you can see and in PCI express connector meassure 12 and 3.3V. Without all that you cant determine what is going on. -
So far I've found 2 missing caps - one under the core and one marked as C529, replaced them and I feel like everything heats up more and faster - the core definitely heats up the fastest, then the power delivery, RAMDAC and memory next, but when I try it with heatsink the heatpipes are cold, fan at 100%.
VBIOS is MX25L1005, 2.7V-3.6V, gets 3.29V, but CS# is always high, SO is always pulled to ground and there is no SCLK signal.
The closest I can see to 5V is 4.45V at the MOSFETs gate, core side.
There is only one fuse marked on the PCB, very close to DVI, it's good.Comment
I have a GTX960 Gaming 4g from MSI and i have the same problem, Vbios CS is always pulled to 3.3V and no SCLK signal, i have no idea what to do. Did you solved your problem?Comment
Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...11-23-2023, 11:02 PM -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by DynaxSCHi,
I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
...05-04-2025, 12:08 PM -
This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...09-07-2024, 02:50 AM
This specification for the Acer Swift Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS boardview and Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:00 AM
- Loading...
