Radeon Vega 64 Model D050 SMB Capacitor identification
  • Slashernator
    • Oct 2021
    • 10
    • United Kingdom
    I've attached a picture of the Vega board model D050 that is missing a SMB Capacitor (At least that's what I think it is!).
    The component is C611 that is similar to C609 and C594 shown in the pic. Can anyone tell me what I need to order to replace it?
    Any other info please shout .
    cheers
  • Slashernator
    • Oct 2021
    • 10
    • United Kingdom
    Re: Radeon Vega 64 Model D050 SMB Capacitor identification
    Forgot to mention that it measures 3mm x 1mm if that helps!
    • Slashernator
      • Oct 2021
      • 10
      • United Kingdom
      Yo guys,
      how do I measure the capacitance of single SMB capacitor removed from the PCB? Any links much appreciated. Most aren't in english.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        With a capacitance meter
        Follow me on YouTube
        Learn Electronics Repair
        • Slashernator
          • Oct 2021
          • 10
          • United Kingdom
          Already subscribed last week. I'll get right on it.
          • R_J
            • 9535
            You may also be able to look up the datasheet for the ic and see what is used in that circuit.
            • Slashernator
              • Oct 2021
              • 10
              • United Kingdom
              Thanks for the assistance.
              Where do i find the datasheet? Really new to this .
              I checked the capacitor and it should've measured 1102 microfarads when set at 2000 microfarad on the meter.
              What does this actually mean when I'm looking to replace the capacitor.
              btw, measured the bad one and it was 70!!
              then where do I find a replacement.
              Any help?
              • Slashernator
                • Oct 2021
                • 10
                • United Kingdom
                Got one.
                What does a measurement of 1096 at 2000microfarads mean?
                • Slashernator
                  • Oct 2021
                  • 10
                  • United Kingdom
                  Gigabyte Vega64 GPU ,What Surface Mount Component is this
                  I have this component that was loose. What SMB component is it?
                  Metric 3216 or imperial 1206.
                  From a Vega64 Gigabyte GPU.
                  The other two circled good components measured 1102 when the capacitance meter was set at 2000 microF. not sure what that means either.
                  Any assistance to identify and aid my understanding, much appreciated.
                  btw, couldn't remove any more solder than shown, set my ksger12 at 500!
                    AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                    The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                    10-01-2024, 01:07 PM
                    AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                    The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                    10-01-2024, 12:46 PM
                    AMD Radeon RX 470 / RX 580 Schematic & Board View
                    The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                    10-01-2024, 12:52 PM
                  • MeetingIncapable
                    Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                    by MeetingIncapable
                    I am new to repairing computer electronics, so excuse any mistakes I make.
                    A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                    I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                    I wanted to replace the capacitor, but I have two questions:
                    • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                    • How do I determine the rating/value of this capacitor? or something
                    05-04-2024, 09:56 AM
                    HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                    This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 05:27 AM
