Sapphire rx470
  • ziko07
    • Jun 2021
    • 102
    • Somewhere
    Sapphire rx470
    Hi ,
    I found bad ir3553 on one phase, but also I see that driver for them not works because on chip ior3567 missing 3v3 enable voltage.
    If I bring 3v3 to enable pin than vddcore is 1v and can see signal on scope to coils
    But problem can't find reason for missing enable signal without schematic
    Can simply shorted this pin to 3v3 but there will not works some security i think like over voltage temperature etc...
    Tnks
  • ziko07
    • Jun 2021
    • 102
    • Somewhere
    Re: Sapphire rx470
    Can someone tell what part us this?
    C2368Z write on it
    • ziko07
      • Jun 2021
      • 102
      • Somewhere
      Re: Sapphire rx470
      Found, it's SN74LVC1G123DCT
        • Jul 2011
        • 6070
        Re: Sapphire rx470
        C2368Z write on it
        How did you find this information because I did not find this information in the data sheet
        • ziko07
          • Jun 2021
          • 102
          • Somewhere
          Re: Sapphire rx470
          First I found some sch here on forum rx580,rx470... and by luck when searched u200 part (sch not as mine pcb) but found part SN74LVC1G123DCT, searching this part on aliexpress found part and image on ic C2383Z( mine was C2368Z),then found texas instrument pdf and found that only C23 is marking
          See all image that I was talking
          Cool isn't it?
          • Bontekop
            • Jun 2014
            • 3
            • Nederland
            Re: Sapphire rx470
            Nice detective work!
            • ziko07
              • Jun 2021
              • 102
              • Somewhere
              Re: Sapphire rx470
              I have one more same card, damaged APW8722a
              Ordered from china tried 3 pcs not worked,because on pcb is 2 same circuits I put ic from good rail and all ok
              Where to buy working chips??
              Tnx
              • ziko07
                • Jun 2021
                • 102
                • Somewhere
                Re: Sapphire rx470
                As I see datasheet
                they work at diferent static frequency
                APW8722 and APW8722B works at 300kHz
                APW8722A and D works at 600khz.
                My ori is with "A" china seller wrote all numbers but not lives option to choose
                Other seller has option to check with A or without
                Can be this problem why not works to me?
                • ziko07
                  • Jun 2021
                  • 102
                  • Somewhere
                  Re: Sapphire rx470
                  Hmm, on my ori ic wrote apw8772a,china is without "a"on the end,but when see datasheet pin3 in my card not connected to gnd,and by datasheet is with extension "a"
                  See image
                  • ziko07
                    • Jun 2021
                    • 102
                    • Somewhere
                    Re: Sapphire rx470
                    I found good apw, card detected rx470 but when I try furmark, pc goes off and get message from image.
                    After second try card dead,ir3553 that I change dead again. Just to ask,card has 5x IR3553M, I used 4x because one is damaged pins on board. Can be reason less power to gpu to crash? Actually I used only 4 phases
