Intel D101ggc
  • moedraznin
    • Mar 2010
    Intel D101ggc
    1 820MF 6.3V was leaking. Replaced, the new replacement was leaking within a few min as well, after I replaced the Power supply. (we are in the comp business so we have them laying around). NO other capacitors look bad. The computer started to give us trouble a while ago.
    What can cause it to keep screwing the capacitors. Its not overclocked and all the fans are working. These intel Boards run the CPU hot. (55C) I verified with intel specs its correct.
    any suggestions besides scraping it?
    Moe.
    • 31246
    Re: Intel D101ggc
    got a foto showing where the cap is?
    and what type are you using?
    • moedraznin
      • Mar 2010
      Re: Intel D101ggc
      The capacitor is right next to the edge by the pci slot.
      The replacemet was purchesed from badcaps. (these people) I even got the better capacitors....
      Thanks,
      Moe.
      (if you still need a picture, I will be at the office later today)
      • Leopard
        • Mar 2008
        • 109
        • Finland
        Re: Intel D101ggc
        Some boards have silkscreening done the opposite way (white stripe is actually +voltage instead of ground). Check the polarity with a multimeter.
        • moedraznin
          • Mar 2010
          Re: Intel D101ggc
          Sure enough, the voltage is backward vs the silkscreen. I will replace the cap with a new one and see how its working.
          Thanks.
          Moe.
