iMac 2011 820-2828 - LED #1 lits for a second then goes off
  • tom.tom
    • Feb 2021
    • 9
    • PL
    Got a 27 2011 iMac that wont boot. In the beginning, when connected to power, the LED #1 was lit and it went off after pressing the power button. I removed the MoBo battery, did SMC reset and now, when plugging the power cable LED #1 lits for a second and then goes off.
    Checked with two other different PSUs - same thing.
    Checked the MoBo with everything disconnected except PSU - same thing.
    Till now have checked PP12V_G3H, PP3V42_G3H in a couple of TPs and adequate voltage is there. Any thoughts what shall I check next?
    Edit1: SCM_RESET_L is 3.55V so the SMC is not in the Reset mode...
    Thanks in advance,
    Tom
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: iMac 2011 820-2828 - LED #1 lits for a second then goes off
    There may be a short to ground on a secondary power rail causing the PSU to enter overcurrent protection.
    Go through the list of power rails and measure resistance to ground for each.
    • tom.tom
      • Feb 2021
      • 9
      • PL
      Just to make sure I understand the power rails descendancy - this is described on the page #3 of the schematics, right?
      So we have:
      1) PP12V_S5 -> PP5V_S3_REG -> PP5V_S0 -> PP1V8_S0_REG
      2) -> PP3V3_S5_REG -> PP3V3_S3 -> PP3V3_S3_MINI, PP3V3_S3_ENET
      3) -> PP3V3_S0 -> PP1V0_FWPHY, PP3V3_S0_SD
      4) -> PP1V5_S3_REG -> PP1V5_S0, PP0V75_S0
      Is that correct?
      Do I also need to track PP12V_S0?
      Since LED#1 is on the PP3V3_S5, shall I suspect just this line: PP3V3_S5_REG -> PP3V3_S3 -> PP3V3_S3_MINI, PP3V3_S3_ENET?
      Also - how do I read page 98 of the schematics, what does "I235 --> POWER -> POWER -> 3.3V -> PP3V3_S5" mean? What's the "I235"?
      • piernov
        • Jan 2016
        • 4439
        • France
        The list of power rails is on page 6 "Power Alias", everything to the left of the '=' signs.
        Page 98 doesn't matter, just some design rules for PCB routing.
        • tom.tom
          • Feb 2021
          • 9
          • PL
          Resistance of the PP3V3_S5_REG_R line measured on the C7790 pin 1 and the GND gives me around 100ohms - is that OK or shall this be considered as a short?
          I'm getting around 3V for a short while on the PP3V3_S5_REG_R line just after connecting the PSU. Does that mean ISL62383 (U7700) is OK and I should look further into PP3V3_S3 and PP3V3_S0 lines or is it too far, because they are powered only after pressing the power button?
          If that's the case, the potential problem should be closer to the U7700?
          Am I right or am I missing something?
          • piernov
            • Jan 2016
            • 4439
            • France
            100 ohms to ground on PP3V3_S5 is probably too low but check resistance to ground on every power rails as I already said, there may be a problem elsewhere.
            • tom.tom
              • Feb 2021
              • 9
              • PL
              Hi @piernov,
              Had time only today to continue on that. With removed CPU, the LED#1 stays on. Reviewed the CPU socked, removed some strange small stuff from two places, but after putting the CPU back, the LED #1 goes off after a second again.
              Any hints where to look at futher?
              • tom.tom
                • Feb 2021
                • 9
                • PL
                ...of course tried with another CPU - same thing
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • SAFC
                  imac 21.5 820-3126-A 2011 dont power on
                  by SAFC
                  The device was brought to me after self-cleaning. After replacing the thermal interfaces, the iMac stopped turning on. While the client was rummaging around in it, he touched the power supply with the processor radiator, after which there was a bang.
                  I examined the power supply, replaced the burnt-out Zener diode ZD36 and the PWM controller DAP017. Now there are standby 12 and 4 volts
                  When connecting the board to the power supply, autostart occurs, only LED 501 lights up. The cooler starts to rotate, after half a second it stops and so on in a circle. For these half a...
                  09-21-2024, 05:20 AM
                • worldofskin
                  iMac A1312 2011 27" 820 - 2828 4mem Error Not booting to OS
                  by worldofskin
                  Hi guys. Hope you are having a great day. This imac iMac A1312 2011 27" with this logic board 820 - 2828. Came to the shop becouse it doesnt boot.I started the apple diagnostic and got 4mem error. I disassembled it, cleaned it and replaced the ram. For a little while it worked normally. But after a while it got to the same state. I tried changing all the ram with a good known working ones. Nothing, i tried a different drive to boot from, nothing. I tried to not boot from sata but i disconnected drive and connected only via usb. nothing. I tried to change the graphic card nothing. I dont have...
                  11-03-2022, 05:07 AM
                • Eleways
                  iMac 27" 2011 with Monterey
                  by Eleways
                  Hi
                  I knew that it's possible to install Os Monterey on iMac 27" 2011.
                  The way it's to change to video card original and use an Nvidia Quadro like K1000 , k3100 etc. and by using a special patch.
                  I suppose that we need to change the firmware or something else as to use this card on a Mac.
                  Anyone have information regarding this?
                  Many thanks!
                  Luke MacWalker!
                  03-29-2022, 07:41 AM
                • ryogadan78
                  iMac A1418 - No LED, no power after overvoltage on Ethernet port
                  by ryogadan78
                  Hi guys, I need your help again.
                  I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                  When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                  06-10-2025, 03:49 AM
