iMac 27" 2011 with Monterey
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi
    I knew that it's possible to install Os Monterey on iMac 27" 2011.
    The way it's to change to video card original and use an Nvidia Quadro like K1000 , k3100 etc. and by using a special patch.
    I suppose that we need to change the firmware or something else as to use this card on a Mac.
    Anyone have information regarding this?
    Many thanks!
    Luke MacWalker!
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: iMac 27" 2011 with Monterey
    https://forums.macrumors.com/threads...grade.1596614/
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • SAFC
      imac 21.5 820-3126-A 2011 dont power on
      by SAFC
      The device was brought to me after self-cleaning. After replacing the thermal interfaces, the iMac stopped turning on. While the client was rummaging around in it, he touched the power supply with the processor radiator, after which there was a bang.
      I examined the power supply, replaced the burnt-out Zener diode ZD36 and the PWM controller DAP017. Now there are standby 12 and 4 volts
      When connecting the board to the power supply, autostart occurs, only LED 501 lights up. The cooler starts to rotate, after half a second it stops and so on in a circle. For these half a...
      09-21-2024, 05:20 AM
    • worldofskin
      iMac A1312 2011 27" 820 - 2828 4mem Error Not booting to OS
      by worldofskin
      Hi guys. Hope you are having a great day. This imac iMac A1312 2011 27" with this logic board 820 - 2828. Came to the shop becouse it doesnt boot.I started the apple diagnostic and got 4mem error. I disassembled it, cleaned it and replaced the ram. For a little while it worked normally. But after a while it got to the same state. I tried changing all the ram with a good known working ones. Nothing, i tried a different drive to boot from, nothing. I tried to not boot from sata but i disconnected drive and connected only via usb. nothing. I tried to change the graphic card nothing. I dont have...
      11-03-2022, 05:07 AM
    • ryogadan78
      iMac A1418 - No LED, no power after overvoltage on Ethernet port
      by ryogadan78
      Hi guys, I need your help again.
      I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
      When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
      06-10-2025, 03:49 AM
    • fr0n1k
      Apple iMac A1311 Mid-2011 (820-3126-A) NO BOOT
      by fr0n1k
      Hello. Got an iMac after a power surge. The PSU survived, but the motherboard did not. Symptoms - after connecting the power, one LED (the rightmost one) lights up, 3.28-3.3v hangs on all legs of the bios flash drive, except for 4. The PCH is heated, low resistance PP3V3_S5 - 30 ohms, PP1V05_S0_PCH - 10-15 ohms. Powered through laboratory power supply 3V 1A to PP3V3_S5, the hub heats up wildly. USB data lines have the same resistance, not underestimated. There is no response to the power button.
      PP12V_S0 - 0.05V (should be 0), PP1V05_S0_PCH - 0.5V (should be 0)
      I've checked...
      10-22-2022, 04:10 AM
