ATI Radeon X800 XT PE AGP
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Rec'd this card - dead.
    In fact, most of the SMT poly caps topside had been removed.
    As it appears all of these have been removed with force,
    two of the caps have lifted the foil on the pcb.
    This isn't so bad - I can pop in some Pana FM to replace
    these in order to test go/no go.
    What I don't have (as it was missing) was the powerlead for
    the heatsink fan. I would like to ID this in order to obtain.
    This is a 3 pin type.
    The HSF end has a smaller connector than the board end.
    In common with these types of connectors, they are keyed
    to go in one way only.
    Can any members help?
  • mockingbird
    • Dec 2008
    • 5484
    Re: ATI Radeon X800 XT PE AGP
    It's a standard fan connector. One of the pins is to measure the RPM and the other two are standard. Take any VGA fan or an old 486 CPU fan and connect it somehow. No need to start purchasing rare parts.
    • Krankshaft
      • Jan 2007
      • 2328
      Just solder the leads from the new cooling fan directly onto the board. Or power it externally from a molex connector on the PSU. Connect the fans positive wire to the yellow wire (+12V) the remaining wire to either of the black wires (ground) in the center. If it's a 5 volt fan connect the positive lead to the red wire (+5V).
      • JEWilson
        • Sep 2007
        • 369
        Can't do that.
        This is a non-standard proprietary ATI all-copper HSF.
        The fan end is socketed as well as the board end.
        I tried a WOL connector but this does not have the
        correct connector to mate to the HSF albeit it is
        a three pin type.
        • mockingbird
          • Dec 2008
          • 5484
          Originally posted by JEWilson
          Can't do that.
          a three pin type.
          Force it if the pinholes are too small. I have done this before.
            AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
            The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
            10-01-2024, 12:46 PM
            AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
            The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
            10-01-2024, 01:07 PM
            AMD Radeon RX 470 / RX 580 Schematic & Board View
            The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
            10-01-2024, 12:52 PM
            AMD Radeon R7 340 / R7 430 Schematic & Board View
            The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
            10-01-2024, 12:36 PM
            AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
            The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
            10-01-2024, 12:20 PM
