HP EliteOne G1 video issue
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I recently aquired a HP EliteOne G1 all in one computer. I tested it and got the result you see in the attached image. Since the computer (according to the specs) has both: a Radeon HD7650A MXM video card and integrated video, I naturally assumed it should work without the MXM card.
    However, it didn't work! Instead, I got a white screen followed by alternating red-green-blue screens. This goes on indefinitely.
    I tried to put the MXM card back but now I don't get anything on the screen. The computer turns on as usual, I hear one beep but the screen remains blank.
    My guess is, a new MXM card should solve the problem. Any other suggestions?
    Cheers,
    SainT
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: HP EliteOne G1 video issue
    Cheers,
    SainT
    Yes, it look like faulty card, you can try to heat up the chip with the hot air station as a temporary fix, no option in the bios to to turn off the discrete video?
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Half-Saint
      • Jan 2010
      • 213
      • Slovenia
      I can't access the BIOS as I don't get anything on screen anymore. Should have tried while it still worked
      I'll try to bake the card in the oven, maybe that will make it work long enough for me to be able to enter BIOS and disable the card.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        No no, oven is not a good idea, use hot air on the chip crystal. Use hot air station or hot air fan. Cover the surrounding area with kapton tape or aluminum foil.
        P.S. Remove the cmos battery, to reset the bios defaults and try without MXM card.
        • Half-Saint
          • Jan 2010
          • 213
          • Slovenia
          I have seen several different techniques for this. I have aluminum tape and I have a hot air station but I haven't used it much. What temperature and fan speed should I set the station to for optimal results? What nozzle width? Some people use a very wide nozzle while the others use narrow (about 1 cm).
          EDIT : I tried resetting the CMOS but it made no difference.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            I would say 450C , 3/4 fan speed, circular motions over the chip cristal, small or medium nozzle 1~2 cm, up to 30 sec in time would do the job perfectly.
            • Half-Saint
              • Jan 2010
              • 213
              • Slovenia
              By "chip crystal" do you mean the core? I just did a heating session on 220C and waiting for it to cool so that I can test it.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Yes, look at the attached image.
                Hot air at 220C is not enough.
                • Half-Saint
                  • Jan 2010
                  • 213
                  • Slovenia
                  Quick update:
                  the heat gun trick worked and the computer is back in working order for now. I didn't use any flux so I'm not sure how long this will work but at least I know that the video card was definitely the culprit.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Quick update:
                    Excellent.
                    The fault was obvious right away, let's hope it will work like that for a while.
                    • Half-Saint
                      • Jan 2010
                      • 213
                      • Slovenia
                      Excellent.
                      True but what puzzled me was the fact that it refused to boot without the card.
