Nvidia GeForce 8500 GT (256MB), bad caps.
  • facuarmo
    • Aug 2019
    • Argentina
    Hello everyone, this is my first thread in here. I hope that I'm doing my question properly.
    The thing is that my cousin sent me a couple of graphics cards he's used on his computer, he uses them around 6/8hs. a day so they get pretty stressed in a daily basis, that said, I found all the capacitors swollen, excepting the ones for lower voltages which I didn't even care about. I then decided to go ahead and replace the leaked aluminium lead capacitor next to Q2 by a low-ESR electrolytic capacitor of the same specifications. The card worked just fine, but I didn't notice that I set the wrong value, instead of using a 1000uF one, I soldered a 1500uF capacitor, I didn't knew about my mistake cause it worked for around one week until my cousin got it back and failed.
    Bad replacement view.
    Later on, I wanted to try actually replacing the rest of swollen but still working capacitors by their 1000uF electrolytic match and noticed my error, finally, I replace the 1500uF by the right 1000uF one, sadly, it didn't work either.
    Clean front view.
    Back view.
    I used some of the SMD pads to solder the new capacitors, so that I don't need to stress the PCB so much with heat.
    Does anybody know what the cause could be? It's not urgent to fix them but I'd like to get them working so that I can learn more about how this complex hardware works. Thank you in advance!
    Last edited by facuarmo; 08-27-2019, 12:57 PM. Reason: Add images, improve description.
  • R_J
    • Jun 2012
    • 9604
    Re: Nvidia GeForce 8500 GT (256MB), bad caps.
    I though the might have been reversed when I looked at other pictures of the board. After finding the same board they look correct
    • facuarmo
      • Aug 2019
      • Argentina
      Originally posted by R_J
      You may have installed the caps backwards.
      No, no, I made sure they were in the right way. The GPU has worked properly two times since the initial replacement of the first capacitor next to Q2. I wonder if the excess of charge of that 1500uF damaged any other component, I just can't tell which one, is there any known component that could get damaged due to a too big capacitor?
      • R_J
        • Jun 2012
        • 9604
        I looked at the wrong board originally
        I would'nt think the extra capacity would damage anything, If it was an issue it would likely have damaged something the first time it was used, but you could check the transistors IE: Q1, Q2 etc. You could have a bad bga connection on the gpu.
        Also check that fuse on the board
        I would have used Aluminum Polymer Capacitors for replacements like the originals
        • piernov
          • Jan 2016
          • 4439
          • France
          The Nvidia GeForce 8500 GT is among those with a defective NVidia GPU, like most NVidia chips from 2006-2008. It would not surprise me if it just randomly failed.
          The capacitor should not be an issue.
          • SistMaticZ
            • Jul 2019
            • 72
            • Morocco
            usually needs reballing . classic
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3266
              • Singapore
              Originally posted by facuarmo
              The card worked just fine. I didn't knew about my mistake cause it worked for around one week until my cousin got it back and failed.
              ^this.^ the fact that it worked for a week rules out the cap replacement being at fault so this exonerates u. if the cap replacement was wrong, the video card wouldnt work at all but instead it worked fine so the fault lies elsewhere.
              looking at this video card, its a gf8 series card with a passive heatsink. this card actually isnt worth fixing. the gpu was probably on its last legs and gave out finally. the gf6/7/8 series are prone to failure with heat and being passive only made it fail faster. he is better off getting another gpu. tell him to get another gpu with a fan. avoid passively cooled gpus. they dont last.
                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                10-02-2024, 08:52 AM
                NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                10-02-2024, 07:51 AM
                NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                10-01-2024, 01:54 PM
                HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                09-12-2024, 03:30 PM
                ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                09-07-2024, 01:00 AM
