Need advice regarding Re-capping AMD R9 280x.
  • reverend
    • Dec 2017
    • India
    Hello everyone! This is my first post in this forum. I will try to keep it short. My ASUS R9 280x 3GB DC2 TOP that I had purchased back in 2014 had been artifacting after an year of use. 30-40 mins of gaming at a stretch would cause artifacting in any graphically demanding game. After crossing out all possibilities, I narrowed down the issue of VRAM overheating. The GPU core never ran above 65 degrees(usually at 55-58) ingame, since my case is well ventilated and I keep the card clean always. Last month the card failed suddenly. There was no display(fans spinned). I reflowed it using the heat gun on my soldering station. Unfortunately, I accidentally blew up a 270 microfarad capacitor during the reflow process by directing hot air towards it. Now the card works normally as before, with the exception of a few static lines on the display and occasional restarts. I have desoldered the old capacitor. Got hold of two similar replacement capacitors( 270 uF, 16V, panasonic). The ones ASUS were using were probably Nichicon. If you have read through all of this, I apologise for wasting your time since I am horrible at making my point in brief and even weaker in making tldrs.
    Now, I have two questions:
    1. Will I keep the entire length of the positive & negative wire attached to the new capacitor? Or should I cut off a portion of it so that there is not too much accumulation of metal, post soldering
    2. Have I damaged the PCB during the desoldering? ( This is my first time doing this). If no, any general tips from here on is appreciated.
    Attached all the necessary pictures pertaining to what I wrote. Any kind of help or technical advice is highly appreciated.
    When the GPU runs without the capacitor
    The GPU PCB
    The area where I desoldered the capacitor from
    The replacement capacitor inserted ( without soldering)
    The area of the PCB which I fear I have damaged
    The reverse side of the same area
    The replacement capacitor of same capacitance and voltage rating.
  • Prolog
    RTX 3080 FE Identifying capacitor
    by Prolog
    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
    I hope these photos make it clear which component I am referring to:
    (yes, the soldering is a bit botched from removing the blown one, I know)
    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
    12-01-2024, 08:27 PM
  • chth96
    If I replace with inferior capacitor, Is it No harm to other IC components at all?
    by chth96
    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
    I know that these capacitor will not last as long as nichicon capacitor...
    12-22-2023, 04:34 AM
  • chth96
    How can I test non-polarized capacitor?
    by chth96
    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
    06-02-2024, 07:31 PM
  • chth96
    Is it no harm to replace with capacitor without ripple current rating?
    by chth96
    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
    Rubycon YK DataSheet (b...
    04-19-2024, 05:19 AM
  • chth96
    Should I replace polymer capacitor?
    by chth96
    a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
    I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
    Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
    Is this ESR value of polymer capacitor correct?...
    11-18-2022, 04:22 AM
