I have this motherboard which turns on but no display. I already done replaced processor,ram, and reflashed the bios with external programmer, also i reflowed chipset, but still there is no display. when i removed the memory there is no beep. could anyone help on this if there is a chance this board to have display?thanks in advance
ECS P4M800Pro-M Ver 2.0 No display
Tags: None
Re: ECS P4M800Pro-M Ver 2.0 No display
Replace the 4 small caps near the CPU socket. These are counterfeit lytics that ECS liked to use.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
You can do the followed tests:
- To test if monitor works: use other monitor to your PC and use your monitor with a different PC
- To test if you PSU works: use a different PSU
- To test if you have graphics problems: you other PCI graphic card
Good Luck!Comment
@ Hkskiller: whatever the outcome, O/P hasn't reported back in almost 2 years, so probably start over with your motherboard.
1st... a bit of history on your motherboard.
- Did the symptoms appear "out of the blue" - i.e. did the motherboard stopped working while in your possession. If not, and this is an item you got from someone else, ask about its history, if possible.
- Knowing with what hardware and up until what point the motherboard was working is helpful to know here.
2nd... what was checked on your motherboard.
- Did you try different (and known good) RAM? PSU? GPU? Monitor? Compatible CPU? (Check the manual!)
- Checked CMOS battery? If not, remove it and try booting without.
- Checked jumper settings?
- Checked for damaged traces (due to mishandling?)
3rd.... if all of the above checks out, time to take a multimeter and start measuring.
- Check all major voltage rails on the motherboard: i.e. CPU V_core, RAM Vdd, RAM Vtt, Vcc AGP, NB/SB Vcc, secondary standby voltage (3.3V/2.5V/1.8V - varies with motherboard and some have more than one).
4th... POST card test (if you have one.)
- Insert a POST card and see if it spits out any codes. If it sits at "00" or "FF", it means your pre-CPU initialization is getting stuck somewhere. Could be due to a bad BIOS/CMOS. Could be due to bad connection on CPU socket (either CPU to CPU socket or failed BGA on CPU socket - especially if the motherboard used a stock Intel cooler, as these tend to warp the crap out of many motherboards.) Could also be bad connection in RAM. Could also be a missing power rail... which is why you need to check #3 above first.
- Make sure to test the POST card in all PCI slots. Not all PCI slots will allow it to display codes, at least IME.Last edited by momaka; 09-01-2019, 07:52 PM.Comment
Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have...
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
- Loading...
