Dell Optiplex GX620 with Oozing Rubycon caps
  • vince88
    • Feb 2008
    • 120
    Unit is a Dell Optiplex GX620 tower with an Intel Pentium-D945 3.4GHz, 3.5GB RAM DDR2 and a 250GB SATA drive.
    Units does not boot up. MoBo (see pic 'mobo') has two clusters of oozing caps, one around the CPU/GPU (see pic 1) and one around the extra 4-pins 12V power plug (see pic 2). All caps are Rubycon, see pic 3.
    master hoarder
    • May 2008
    • 12164
    • Bulgaria
    Re: Dell Optiplex GX620 with Oozing Rubycon caps
    Yep, nothing new here. Bad Chemicon KZJ and RUbycon MCZ in a Dell mini-bake oven PC. Those Pentium D chips put out a lot of heat, and in a small case, just about any regular electrolytic cap will cool. So if you do recap it, you might want to use polymers (i.e. polies). And maybe see if you can add an extra fan in the system or otherwise optimize the cooling. Generally, those Dell cases have decent cooling, but it's just that the P4/PD CPUs they use produce too much heat for that case.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      The OP specified that it is a tower, which sounds like a mid tower case to me, not a SFF or slim (thin) desktop.
      Don't you mean cook?
      Or to optimize the cooking?
      Just giving you a hard time. Not trying to make fun of you.
      I'd say what accounts for the failures is that Rubycon MCZ simply don't handle heat well, and Chemi-con KZJ are unstable even on the shelf.
        master hoarder
        • May 2008
        • 12164
        • Bulgaria
        Originally posted by Wester547
        Don’t you mean cook?
        Hmm, I did. But I was holding a cool beer while typing this, so maybe that's why. And also because it was my second beer for the night instead of having a proper dinner. Oops.
        I bet I will wake up tomorrow to an inbox full of badcaps.net emails/threads with people correcting my posts from tonight, lol.
        • Fast Alpha
          • Feb 2013
          • 245
          • United Kingdom
          The case should of had better fans and airflow, to avoid that happening.
          http://www.hse.gov.uk/pubns/indg305.pdf
            master hoarder
            • May 2008
            • 12164
            • Bulgaria
            Looking back at the O/Ps pictures, it does appear that this is an SFF or USFF desktop and not a full tower. Look at the motherboard - it has only a PCI-E and a PCI slot. The full tower has 4 slots.
            Nevertheless, those MCZs would have likely blown even in the full tower. I just got two of these OptiPlex GX6xx and GX7xx machines (I think one was a GX620 and the other a GX760), and one of them has similarly-blown Rubycon MCZ caps. When I eventually get around to it (might be in the early spring due to cold weather right now, and I need to do a full clean-up and de-dusting of these towers outside), I'll see how the cooling is in these towers. I'm thinking that reversing the front 120 mm CPU/case fan (so that the tower blows hot air from the front and takes cool air from the back) might be better for the motherboard's cooling. But that's just a theory in my head right now.
            Yes, indeed.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              You're right, it's a SFF machine (not USFF). No wonder they failed. Even the slim desktop version has 4 slots IIRC. Part of the problem is an inadequate cooling design, but the other part of the problem is that MCZ are just really sensitive to heat (not “plague” capacitors though). For an example (I'm sure you know this), in the HP DC5000 and D530 SFF computers, the MCZ in the VRM out are almost always bulging and leaking, often before any of the Teapos bulge, but the FL are never bulged.
              But yes, improved cooling would certainly help the capacitors in these machines last longer.
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                Yes, they are sensitive indeed. But when well-cooled, they will last a very long time and not give problems at all, unlike Chemicon KZG and KZJ, which will fail on their own, with or without use.
                Similar ordeal in the HP DC7700 (and possibly DC7600 and DC7800) boards. I got a board from a DC7700 "mini" tower (not SFF or USFF)... i.e. mATX board. All of the Rubycon MCZ caps on the high CPU side along with the many elsewhere on the board were bulging and leaking. The Rubycon MBZs next to them were fine, though. However, I'm pretty sure it wasn't a bad batch of MCZ caps, because the board had quite a bit of darkening of the solder mask on the underside of the chipsets and also around the VRM area, implying that the tower had either poor ventilation or there was a Pentium D fireball in the CPU socket (or both ).
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16955
                  ...or used polymer caps from the start... Those little toaster boxes don't usually get the best of a good set of polymer caps!
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Fast Alpha
                    • Feb 2013
                    • 245
                    • United Kingdom
                    Polymer caps are they easy to solder on and are better at cool.
                      master hoarder
                      • May 2008
                      • 12164
                      • Bulgaria
                      Not a whole lot. But if you have a crappy iron, then yes, because they do have slightly thicker leads usually.
                      You mean do they withstand heat better?
                      - It depends. Polymers still have a finite life/endurance, just like regular "wet" electrolytic caps. But because the electrolyte in polys is dry, high temperatures may affect them a little less. So for example, a 105C-rated poly cap may have the same 2000 hour endurance rating as regular wet electrolytic cap. But for every 10C drop in temperature, the endurance life increases 10-fold for certain polymer series. Thus, at 100C, a poly cap could last up to 20000 hours. Whereas for a regular 'lytic, the endurance life usually only doubles (i.e. 4000 hours for a 2000-hour electro cap) for every 10C drop in temperature.
                      • Wester547
                        • Nov 2011
                        • 1268
                        • USA.
                        Actually, for every 20ºC drop, the lifespan of polymers increases 10x. See here, page 12. So it would be 20,000 hours at 85ºC if it was rated up to 2,000 hours at 105ºC.
                        The disadvantage of polymers is that because they rely upon electrons to achieve conductivity, they are more sensitive to excessive bias and inrush currents. The mobile ions in a liquid electrolytic solution are relatively insensitive to overvoltage and surge currents (provided that the cap hasn’t been sitting in storage for too long, of course).
                        • Fast Alpha
                          • Feb 2013
                          • 245
                          • United Kingdom
                          Yes I meant are they better at withstanding the heat.
                            DELL OptiPlex 3080 OptiPlex 3000 i5-10500T Specification for Upgrade or Repair
                            This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            09-12-2024, 02:30 PM
                            DELL OptiPlex 3070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
                            This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            09-12-2024, 03:44 PM
                            DELL OptiPlex 7050 OptiPlex 7000 i5-7500 Specification for Upgrade or Repair
                            This specification for the DELL OptiPlex 7050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7050 boardview and OptiPlex 7050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            DELL OptiPlex 7080 OptiPlex 7000 i5-10500T Specification for Upgrade or Repair
                            This specification for the DELL OptiPlex 7080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7080 boardview and OptiPlex 7080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            DELL OptiPlex 7080 OptiPlex 7000 i7-10700 Specification for Upgrade or Repair
