AOpen DX34R-U Dually - Bad Caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Yet another Aopen with the plague.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: AOpen DX34R-U Dually - Bad Caps
    I know this is ancient,,, but do you remember...
    - The four grouped 2200uF 16v 12.5mm KZE in black and gold by the PSU connector?
    Did those look like fakes to you?
    I just got two of these NOS and frankly I don't remember seeing black and gold KZE before.
    Thanks.
    Mann-Made Global Warming.
    - Dr Seuss
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
