HP Compaq 4000 Pro <HELP>
  • lbwlow
    • May 2015
    • 125
    • Malaysia
    Greetings people
    I got a HP Compaq 4000 Pro SFF desktop that won't power up (not to say it totally won't), bought it from a junker though. With or without RAM, diagnostic LED indication will blinked red for 2 times (1 blink for every second followed by 2 second pause), same as the beep code. It power up as soon as I switch on the mains, both CPU and PSU fan spins for just 1 or 2 seconds and stop spinning after that, and the beep and blink codes continues.
    I tested the CPU, RAM and HDD on other PC and it all works.
    Here a video to my blink code:
    https://www.youtube.com/watch?v=1pZD...ature=youtu.be
    I refer my blink code to HP's service manual and I don't find a match.
    But if I disconnect 4 pin CPU power connector, I get a different blink code, 4 blinks, 1 blink every second followed by a 2 second pause. And there a match, according to the service manual it is power failure, power supply overload.
    This was a proprietary HP PSU, with 6 pin, another smaller 6 pin and 4 pin CPU power connector. I jumped started the PSU by shorting green to black wire, the PSU does power up and the fan is running at full speed. Wasn't sure if this is how it behaves though, I have non of a experience dealing with HP SFF system.
    In this board have some KZGs though, wasn't sure they are bad, they all looks good, no bungs, leaks or bloat.
    Can anyone please share with me with any experience with HP SSF system? And help identify the unknown blink code that is not listed in the documentation. Any help is appreciated
    • 30997
    Re: HP Compaq 4000 Pro &lt;HELP&gt;
    maybe there is a short on one of the power lines.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Was there a fan for the processor heatsink? you might need to connect a fan to one of the headers on the motherboard before it will power on.
      Also you need to connect the P4 connector, googling image search shows for the 4000 that it is connected, and went away on 6xxx and 8xxx series.
      • lbwlow
        • May 2015
        • 125
        • Malaysia
        Hmm, can u elaborate more on which power line to be specific?
        Yup, there is, it has a air duct, I removed it to snap some pics, similar to dell BTX design.
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          If I had to guess based on other information, like this
          http://h20564.www2.hp.com/hpsc/doc/p...ts.oid=3658084
          and this
          http://h20564.www2.hp.com/hpsc/doc/p...r_na-c00274415
          and here
          http://h20564.www2.hp.com/hpsc/doc/p...mmr_kc-0100459
          It's a recurring theme.
          I would say either the cpu fan is not sending a PWM signal to the board and the board is going into protection mode to prevent damage or someone has flash the wrong bios on to that board.
          It's unusual especially on a business class workstation to have undocumented diagnostic code, unless hp compaq add it to a bios update after release.
          • lbwlow
            • May 2015
            • 125
            • Malaysia
            and this
            and here
            Thanks for the info
            If it was the fan not sending PWM signal is there anyway that i can bypass it ? I did remove the board from its casing and attempt to power up the board with a stock intel HSF sitting on top for testing and use a slight force to connect the stock intel fan power connector to HP's connector, and it still the same.
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              Originally posted by lbwlow
              Thanks for the info
              Use another PWM fan, which sounds like you did. You can measure voltage from the PWM wire usually between 1 to 3.3v, I tend to use a thin sewing pin and the alligator clip leads on my DMM. Ground one to the case and attach the other to the sewing pin, I usually insert the sewing pin first then attach, and ensure it doesn't come in contact with anything nearby that could potentially short it and cook it.
              You could remove PWM wire from the connector, it's usually held in with a friction clip, lifting it and removing the wire will do it, using a simple DC voltage Fan will do the same trick. It's possible that it's not sensing RPM and throwing the error code.
              You can also swap processors, since thermal shutdown is caused by a sensor either on the board or from internal sensors on the processor. So if you have another lga775 chip, give that a try.
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                Thanks for the info
                EDIT:
                ummmm what the shit? duplicate after editing?
                Use another PWM fan, which sounds like you did. You can measure voltage from the PWM wire usually between 1 to 3.3v, I tend to use a thin sewing pin and the alligator clip leads on my DMM. Ground one to the case and attach the other to the sewing pin, I usually insert the sewing pin first then attach, and ensure it doesn't come in contact with anything nearby that could intentionally short it and cook it.
                • lbwlow
                  • May 2015
                  • 125
                  • Malaysia
                  Okay, thanks for the tip
                  Will try it tomorrow and report back on how it goes.
                  I already swap the processor, from the original e5800 that comes with it to e2200, and it still the same
                    • 30997
                    did you test the psu on another system?
                    • lbwlow
                      • May 2015
                      • 125
                      • Malaysia
                      I can't test it, because I don't have other system available that share similar PSU.
                        • 30997
                        well you said "if I disconnect 4 pin CPU power connector, I get a different blink code, 4 blinks, 1 blink every second followed by a 2 second pause. And there a match, according to the service manual it is power failure, power supply overload"
                        that makes me think the psu has a problem, or the cpu connector has something shorted causing the psu to shutdown.
                        the fans are the giveaway.
                        • lbwlow
                          • May 2015
                          • 125
                          • Malaysia
                          I tested the stock PWM fan wire and it give me voltage output of 1.3-1.5V. If it was because of a faulty CPU temp sensor on the motherboard is there anyway that I can bypass it ?
                          I open the PSU and do some simple test using DMM today, and I found a diode seems to be bad, tested using diode mode on my DMM, on forward voltage i got 0.318V, but when tested in reverse, I got a reading that rise from 0v until it says OL. It was tested in circuit though.
                            • 30997
                            that reading is probably o.k., your seeing a capacitor discharge.
                            • lbwlow
                              • May 2015
                              • 125
                              • Malaysia
                              U were right, I removed the diode off circuit for testing and it is working as it should.
                              Now i figured something weird, when older LGA775 processor is inserted for testing, what i tested is Celeron D and Pentium 4 506, the LAN port LED would light up when I power on the system, it doesn't always light up, sometime it would, sometime it wouldn't. With those processor in, the CPU and PSU fan won't switch off this time, and there is no beep code. But the processor barely warm up at all.
                              What does the LAN port LED that lighting up indicate?
                                • 30997
                                i think it means the lan chip is getting power AND detecting an active connection.
                                • saeedkhan
                                  saeedkhan commented
                                  Editing a comment
                                  Can u provide Me BIOS of that system.
                              • kaboom
                                "Oh, Grouchy!"
                                • Jan 2011
                                • 2507
                                Recap the power supply. It's full of crapxons, teapos, and ltecs.
                                Those systems acted real strange once the caps started going- you then had the MB caps attempting what the ones in the PS should've been doing.
                                You may have to recap the MB anyway, if it's got KZGs/KZJs...
                                "pokemon go... to hell!"
                                EOL it...
                                All style and no substance.
                                guilty,guilty,guilty,guilty!
                                guilty of being cheap-made!
                                • lbwlow
                                  • May 2015
                                  • 125
                                  • Malaysia
                                  Okay, I will desolder a couple caps off the PSU and do capacitance measurement and see how it goes
                                    HP Compaq Pro 4300 SFF Compaq Pro 4000 i3-3220 Specification for Upgrade or Repair
                                    This specification for the HP Compaq Pro 4300 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro 4300 SFF boardview and Compaq Pro 4300 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-12-2024, 03:30 PM
                                    HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                    This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-12-2024, 03:44 PM
                                    HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                    This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                    HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                    This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                    09-12-2024, 03:36 PM
