Biostar TA780G M2 HP Replacement for OST RLG 10V 1000uf
  • turbo
    • Dec 2014
    • uk
    I have the above board which is faulty and the above capacitor is swollen at top. I have read on another forum a member had the same issue and replacing the cap cured his faults.
    It is 8mm dia. x 13mm Long. However when I looked on the OST site it quoted the sizes for this cap to be 10mm x13 or 10 x 16 or 10 x20 which confused me further.
    I have looked on RS components site and they have:
    Panasonic FC and FM series
    AL lXZ series
    Nichicon PM, PS AND VR series
    They vary in size from 8 x 16 to 8 x 20 also 10 x16 and 10 x 20
    Would any of these be Aasuitable series and does it matter on the dia and length.
    If none of these are a suitable replacement could you please suggest what I should fit.
    Many thanks
  • omon
    Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
    by omon
    I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
    This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
    I'm attaching the pictures of the bad cap.
    Thank you so much!...
    04-28-2021, 05:43 AM
  • the_rem
    Unknown transformer : how to find a good replacement part ?
    by the_rem
    Hello guys,
    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
    04-23-2025, 01:48 AM
  • ezenia
    PS4 controller left stick potentiometer replacement issue
    by ezenia
    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
    09-30-2023, 02:19 PM
  • P4C800
    ASUS P5A and P2B-S recapping. Searching old datasheets.
    by P4C800
    I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
    There are three mainboards:
    - ASUS P5A rev 1.04
    - ASUS P2B-S rev 1.03 "Rubycon"
    - ASUS P2B-S rev 1.03 "Chemi-Con"
    If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
    They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
    P5A
    10-09-2023, 05:55 AM
  • boosti45
    Macbook pro logic board replacement parts quesion
    by boosti45
    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
    08-21-2024, 05:23 AM
