Amd vii xtal identification
  • Ros2468
    • Feb 2022
    • 16
    • Norway
    Does anyone got any Intel to what xtal this is - i cannot figure?
    I believe pin 3 is the output and goes through a r33 then under the core and my measurements are very bad
  • pb1911nt
    MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
    by pb1911nt
    Hello forum,
    I'm still relatively new to the world of electrical repairs.
    I have a Macbook here that I can't figure out
    When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
    I removed the logic board and took a few measurements.
    But I can't really figure it out.
    At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
    09-07-2025, 11:35 AM
  • ResoluteHawk
    Quanta 0P5 (DA0P5HMB8E0-Rev E) Missing ACDRV
    by ResoluteHawk
    I have an HP 15-DY laptop in because the battery is not charging.
    If I use a charged battery, the laptop powers on but the battery will not charge, however the orange charge light does turn on. The laptop loses power as soon as I disconnect the battery.
    I've replaced the BQ247 chip with a known working one and I get the same issue and the same measurements.
    Measurements are as follows:
    BQ728 IC
    VCC (Pin 20) => 19V
    CMSRC (Pin 3) => 0.8V (This is a problem but I can't figure out what's causing the low voltage)
    ACDRV (Pin...
    04-10-2025, 11:36 AM
  • Shulgin
    Acer predator XB241YU Component identification
    by Shulgin
    I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
    After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
    In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
    I...
    05-11-2024, 11:06 AM
  • McWhitePink
    Help, 38.4MHz xtal has no output on MSI z690
    by McWhitePink
    Can anyone help me, why the board doesn't have 38.4M xtal output? Is it the XTAL dead or the PCH dead? for this reason, the board doesn't power on.
    12-16-2023, 03:23 AM
  • Tend0
    hp elitebook 840 G4 no 5v IC identification
    by Tend0
    Hello everythone
    i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
    i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
    05-31-2025, 09:13 PM
