Modify Acer V65X BIOS to initialize the CS4237B chip
  • kotel studios
    • Dec 2024
    • 205
    • Poland
    Since the ACER V65X doesn't have the onboard CS4237B audio and my own V65XA BIOS is toast, I need some help trying to figure out how am I supposed to put the init instructions from lets say an Acer V58XA with the same audio chip into the V65X BIOS.
    Anybody who could be kind enough to at least seperate the part where V58XA initializes the sound chip?
    Attaching the V58XA and V65X BIOS'es in the zip files.
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • JoWed
    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
    by JoWed
    Hello Community,
    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
    07-01-2025, 09:32 AM
  • inck243
    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
    by inck243
    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
    The BIOS...
    07-25-2024, 09:17 AM
  • BMCappelletti
    Asus Chromebox CN62 - wrong chip put on BIOS reader
    by BMCappelletti
    Long story short:
    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
    - gave the computer to his son a couple years later
    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
    (seems like the story was not that short)
    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
    01-08-2025, 07:27 PM
