PowerEdge t310 It doesn't recognize anything on USB ports
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    4 rear ports nothing, two front ports nothing, two internal ports nothing, observably no capacitor deformed or in bad condition is perceived, I never ran into a problem of these guys I need to guide me,
    PowerEdge T310
    ST: 8MKX2V1
    ExSvTg: 18779650237
    All comments will be well received, thank you
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    check in bios if usb ports are disabled.
    any power output??
    • the Benninger
      • Nov 2022
      • 189
      • venezulan
      thks ant3202 How can I talk about entering the BIOS without I can't press any key, this is the main problem, I can't verify anything in the BIOS , take the precaution of measuring the voltage in all the outputs, they all have 5v in fact I have an external SSD with LEDs that indicate that it is energized and another that indicates read and or write, the power well and the read does not do anything tested on all ports, in the DELL forum they indicate to remove any connected PCIe board and boot without them that did not work
      Just like you, I have to think that they are disabled in the BIOS. It is impossible for all the ports to be damaged at the same time. Before a general cleaning and maintenance job, I managed to boot normally with ws2012. After the maintenance, I am asking to press the F1 key to continue since the CMOS has been reset.
      • the Benninger
        • Nov 2022
        • 189
        • venezulan
        The question is the following: can the BIOS info be edited in a backup of it to solve it or does it have to be done directly from the options? Today I'm going to try with a card to add two PCIe x1 USB ports. I'm almost sure it won't work.
        • mon2
          • 14220
          Locate the CMOS battery and short it and/or remove the coin cell battery. This will cause the BIOS configuration to reset to factory default which should then re-enable the USB ports.
          • the Benninger
            • Nov 2022
            • 189
            • venezulan
            thks so m mon2 ,was done and no favorable result
            • the Benninger
              • Nov 2022
              • 189
              • venezulan
              Maybe host controller problem, any boardview or schematics thanks
              • the Benninger
                • Nov 2022
                • 189
                • venezulan
                I found a BIOS in the support with the same Verison 1.11 update this with the programmer and the results remain the same
                  Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                  09-06-2024, 09:40 AM
