MSI X570 GAMING PLUS cpu led on after driver burnned.
This topic has been answered.
  • smic717394
    • Jun 2017
    • 93
    • Spain
    Hi guys,
    I bought a motherboard with a Chipset IR35201 burned. Also, I found one of the dual mosfets shorted. So I changed the IR35201 and the 2 dual mosfets, and the short is gone, the board is starting, rgb led are on, but the NB fan runs at full speed, and the debug led for CPU lights up. I tried to flashed the bios using the flashback, it flashes fine, the board restarts, but still the same. If I measure the resistance on the 2 dual mosfets coil, I get with the CPU in 1ohm, and without the CPU I can't remember but megaohms. So, I thought the CPU is bad, I tried the CPU on another board and its fine, also I tried another CPU on this board and it's still the same.
    Without the CPU in the output on this coil are like 0.4V and with the CPU in, nothing. I also changed the 5 drivers on the back IR3598, and still the same.
    Could it be a bad IR3598? I tried injecting 0.9V on the coil and with the CPU in there is no voltage drop but it takes about 2A, without the CPU is 30mA, but its not the CPU. I tested the CPU and its fine. Can someone help.
  • Answer selected by smic717394 at 01-23-2025, 07:16 AM.
    noname2024
    • Aug 2024
    • 260
    • CỎ MỸ XỊN
    Ic pwm IR3521 have program
    • noname2024
      • Aug 2024
      • 260
      • CỎ MỸ XỊN
      • smic717394
        • Jun 2017
        • 93
        • Spain
        IR3521 need to be programmed? How do I program this ic?
        • smic717394
          • Jun 2017
          • 93
          • Spain
          Ok, I see I need a programmer USB005, that costs on aliexpress €70-- the board is probably less.
          • smic717394
            • Jun 2017
            • 93
            • Spain
            I´m going to get the C8051F340 Development Board and the C8051F Emulator Downloader and try to flash it. Just so That I understand, the file you sent (thank you) do I click on load config file in IR PowIRCenter and upload the IR35201_MSI_MS-7C37_AMD_X570_8n2_RevA_AC_2019-01-15 and then write all config?​
            • smic717394
              • Jun 2017
              • 93
              • Spain
              Hi, my USB005 is few days away, just to confirm I know what I´m doing.
              On the Motherboard VU1(ir35201)
              Connect SDA to the VC13 (pin 24 of the ir35201)
              Connect SCL to the VC11 (pin 25 of the ir35201)
              GND to any ground pin
              Connect the PSU 24pin and the cpu power pins
              Turn on the board
              OpenPower Gui or IR PowIRCenter
              Auto populate
              Scan Full Address Range
              Click on the card on the left
              Click on the multi device programmer button (flame)
              Click on select configuration and select the file given here
              Then check the trim and user boxes
              Click on Program and Verify
              With a little luck everything passes​
              • smic717394
                • Jun 2017
                • 93
                • Spain
                Hi, I got the board running, thank you for the firmware. I´m now installing windows, how Do I test if all the cpu phases work fine? Should i run OCCT?
                • smic717394
                  • Jun 2017
                  • 93
                  • Spain
                  Hi, the firmware you sent works great, but I have a board here with the original chip, can I backup the original chip configuration with IR PowIRCenter ? Is just a matter of just clicking save config after auto populate and select the chip because I notices if I click read all reg the values on common changes?
                  Thank you
                  • Ronald100
                    • Jan 2022
                    • 7
                    • Brazil
                    Hello everyone, first of all, sorry for the English, but I have a problem like this, so in my case it's a gigabyte x570s aorus master with the blessed xdpe132g5c shorted to 12 volts, I changed a tda and the xdpe, but to work I need a functional firmware, does anyone have a file or board that can extract the firmware?
                      ASUS TUF Gaming FX506HF-HN028-GAMING Notebook F15 Specification for Upgrade or Repair
                      This specification for the ASUS TUF Gaming FX506HF-HN028-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HF-HN028-GAMING boardview and FX506HF-HN028-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:38 AM
                      ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook A15 Specification for Upgrade or Repair
                      This specification for the ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FA506IU-HN153T-Gaming boardview and FA506IU-HN153T-Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 11:20 PM
                      ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                      This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 09:01 AM
                      ASUS TUF Gaming FX505GM-AL323-GAMING Notebook Specification for Upgrade or Repair
                      This specification for the ASUS TUF Gaming FX505GM-AL323-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505GM-AL323-GAMING boardview and FX505GM-AL323-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      MSI Gaming GP73 8RE-062UK Leopard + Gaming Voucher Notebook GP Specification for Upgrade or Repair
                      This specification for the MSI Gaming GP73 8RE-062UK Leopard + Gaming Voucher Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP73 8RE-062UK Leopard + Gaming Voucher boardview and GP73 8RE-062UK Leopard + Gaming Voucher schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-06-2024, 08:41 AM
