GIGABYTE Radeon HD 5970 dead?
  • chrle
    • Sep 2013
    • 158
    • slovakia
    hello, II have problem with my radeon, when I turn on my pc,graphic card fan start on 100% speed and 2 red led diodes on card,no signal on monitor.
    how to repair this? I have 1000w corsair PS.
  • holmes222
    • Aug 2009
    • 61
    • INA
    Re: GIGABYTE Radeon HD 5970 dead?
    this gpu is likely overheating .. i have too with the same symptom
    maybe need reflow or reballing .. or maybe it just dead
    try add a fan directly blowing to back of gpu
      master hoarder
      • May 2008
      • 12164
      Are you the original owner of this card and have you had it working before you got it? If yes, then try new thermal compound. If problem persists, it's probably time to reflow or reball the GPU (at which point, it may not be worth it if you don't have the tools and equipment... so just sell on eBay or locally as "for parts or repair").
      • chrle
        • Sep 2013
        • 158
        • slovakia
        yes I have Scotle 858D+ rework station,I will try to reball.
          master hoarder
          • May 2008
          • 12164
          Try the new thermal compound first. If that doesn't work, then do the reflow/reball.
          However, I should mention that the 858D+ probably would make this very difficult to do, since it can't really provide enough heat flow to remove the chip. At the very least, you will need some kind of bottom heater (electric stove top works with a bit setting-up). And even then, there's a high chance you will damage or pop-corn the chip with the top heat from the 858D+. But if nothing else, give it a try and let us know how it all goes. The card is alreade not working, so not much to loose. Though if you do want to make some money off of it, sell it on eBay "for parts or repair". Should get a reasonable pocket change for it.
          • chrle
            • Sep 2013
            • 158
            • slovakia
            hello,I have strange problem with this card,
            I change new thermal compound,when I put board on cooler board it power on and green diode light.
            when I start puting spings on bga chips then green light turn off,after restart again 2 red diode lights. is coolerboard shorting something?
              AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
              The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
              10-01-2024, 12:46 PM
              Thermal pad thickness for various laptop GPU / Graphics Cards
              ASUS Dual RTX 2070 OC 8GB
              ASUS ROG STRIX RTX 3080 OC
              ASUS ROG STRIX RTX 3090
              ASUS TUF Gaming RTX 3080 OC Edition
              ASUS TUF GTX 1660 S-O6G GAMING
              EVGA RTX 3060 Ti XC GAMING 8GB
              EVGA RTX 3060 XC GAMING 12GB GDDR6
              EVGA RTX 3080 FTW3 ULTRA GAMING
              EVGA RTX 3080 TI FTW3 ULTRA GAMING
              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
              Gainward RTX 2080 Phoenix GS Specs
              Gainward RTX 3070 Phoenix 8GB
              Gainward RTX 3080 Ti Phoenix
              GIGABYTE AORUS RTX 3080 MASTER 10G
              02-09-2024, 08:08 AM
              AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
              The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
              10-01-2024, 01:07 PM
              AMD Radeon RX 470 / RX 580 Schematic & Board View
              The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
              10-01-2024, 12:52 PM
              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
              by momaka
              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
              And a shot of the label:...
              01-26-2022, 03:26 AM
