replace intel 865glc 6.3V 820 cap 8mm with 1200uF ???
  • supersabre
    • Feb 2006
    • 45
    I have an intel 865 glc with lot of bulging nichicon hn(oragnge marking).
    The bad caps are all 8mm. tight spacing restricts the diameter of the caps and only 8mm will fit.
    I have hard time of finding the best substitute for it.
    I check digikey.com, but they don't have 8mm for 6.3v 820uf and 1000uf.
    They have 8mm panasonic fm 1200uf 6.3v .
    Question: Is it ok to replace 6.3 820uf with 6.3 1200uF panasonic fm series?
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: replace intel 865glc 6.3V 820 cap 8mm with 1200uF ???
    Question: Is it ok to ?
    Yes, it is O.K for replacing 6.3 820uf with 6.3 1200uF panasonic fm series .
    It will be more better if you use with super low ESR 1500uF 6.3v D8mm.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
