APPLE iMac A1311 ,no power
  • amennone
    • Feb 2015
    • 63
    • italy
    Main board : 820-3126-A
    Power : OT8043-290H R03BE9-0008I- apple P/N: 614-0444
    EMC 2428
    Problema , alla pressione del tasto power(S5010) tutto spento , led 501acceso .
    Sui pin dell'alimentatore sono presenti :
    Pin 6 4v6
    Pin2 12v
    Sul pulsante power sono presenti 3v3 , che alla pressione si genera il segnale SMC_ONOFF_L , il quale va al pin 104 di U4900 = H8S2117 LFBGA
    ho difficoltà nel capire quale sequenza , quando arriva il segnale SMC_ONOFF_L, deve
    eseguire U4900 per attivare l'alimentatore
  • mon2
    • 14679
    Power : OT8043-290H R03BE9-0008I- Apple P/N: 614-0444
    EMC 2428
    Problem, when pressing the power button (S5010) all off, led 501 on.
    On the pins of the power supply there are:
    Pin 6 4v6
    Pin2 12v
    On the power button there are 3v3 , which when pressed generates the signal SMC_ONOFF_L , which goes to pin 104 of U4900 = H8S2117 LFBGA
    I have difficulty in understanding which sequence, when the signal arrives SMC_ONOFF_L, should
    run U4900 to activate the power supply
    • amennone
      • Feb 2015
      • 63
      • italy
      Problem, when pressing the power button (S5010) everything is off, led 501 is on.
      On the power supply pins there are:
      Pin 6 4v6
      Pin2 12v
      On the power button there are 3v3, which when pressed generates the signal SMC_ONOFF_L, which goes to pin 104 of U4900 = H8S2117 LFBGA
      On L7710 there are 3v3, on L7750 0 Volts
      PP12V_G3H_ACDC 12v O.K.
      =PP12V_G3H_S5_FET
      =PP12V_G3H_3V42
      PP12V_S5_RSN o.k
      U7700= ISL62383
      pin4 = 5v
      pin5 = 5v
      pin12= 3V9
      pin17= 12v
      pin24= 0v PM_EN_P5V_S3_REG
      PM_EN_P5V_S3_REG , from the diagram is generated by U6900 , these are the voltage values
      U6900= 74LVC08
      pin1= 0v
      pin2= 3v2
      pin3= 0v
      pin4= 0v
      pin5= 0v
      pin6= 0v
      pin7= GND
      pin8= 0v
      pin9= 0v
      pin10= 0v
      pin11= 0v
      pin12= 0v
      pin13= 3v2
      pin14= 3v3
      The power supply is working, if I put pin1 of the J601 connector to ground, PP12V_S0_PS is present
      a little help on how to proceed, thanks.​
      • mon2
        • 14679
        Remove all power. Measure the resistance to ground of each inductor (usually grey in color; 2 leads). Checking for a possible shorted power rail.
        • amennone
          • Feb 2015
          • 63
          • italy
          With a bench power supply I powered PP12V_G3H_ACDC, the 501 LED is on, I measure a consumption of about 400 milliamps, it is known that it heats U1800
