Mac mini 2018
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Mac mini 2018
    Hi all, did you solved? I have same identical problem but I have PP5V_G3S 5V
    PP1V_PRIM 0V
    PP1V2_PRIM 0V
    led of Mac Mini is blinking
  • mon2
    • Dec 2019
    • 13830
    Pragmatiko - with no power , measure the resistance (not diode mode) to ground of PP1V_PRIM and the PP1V2_PRIM rails. Post your measurements.
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      on PP1V_PRIM 46ohm, and PP1V2_PRIM 5Kohm
      Tks
      • mon2
        • Dec 2019
        • 13830
        What is the history of your unit? Just stopped working one day? Any liquid damage? This model appears to be plagued with the same fault.
        PP1V_PRIM @ 46 ohms, to me, sounds too low for a normal logic board. This rail is also used to power the USB PHY.
        Carefully, measure the voltage to ground of:
        PMU_P5V_USBC_ISENSE
        PMU_P5V_USBA_ISENSE
        PP5V_G3S_USBA
        PP5V_G3S_USBC
        PP3V3_G3S_WLANBT
        PP3V3_G3H_ENET
        • Pragmatiko
          • Jul 2013
          • 468
          • IT
          no liquid damage. I got it from a friend that says the unit stop to working. Now when i plug it i can see only led to blinking. i will che the voltage you suggested me and reply to you soon.
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            PMU_P5V_USBC_ISENSE voltage not present
            PMU_P5V_USBA_ISENSE voltage not present
            PP5V_G3S_USBA voltage present 5V
            PP5V_G3S_USBC voltage present 5V
            PP3V3_G3S_WLANBT voltage present 3,3V
            PP3V3_G3H_ENET voltege present 3,3V
            please read above
            • Pragmatiko
              • Jul 2013
              • 468
              • IT
              update, i have removed L7821 and L7822 and now voltage side IC is present. Then i suppose that 44ohm resistance downstream coil is not good.
              • mon2
                • Dec 2019
                • 13830
                Can you clarify? There is still a FB connection resistor @ R7820. Carefully remove it. Do not power up without these components. Great that you are comfortable with this process as the parts are incredibly small. There is also a cluster of pins on U7800 that directly bond to this rail (R12, T12, etc.) - so U7800 is still a suspect.
                Then confirm which side of this rail is shorted? Is it the producer (U7800) or consumer side. In your post, do share the pin # of the removed coil(s) that show the 44 ohms to ground.
                One tool that would help here and we are considering it to source soon is a low ESR capacitance meter that can measure in milli-ohms. With such a tool, it should be possible to test each cap or whatever on the board to confirm if it is shorted or not. There is a sea of parts onboard to investigate.
                • Pragmatiko
                  • Jul 2013
                  • 468
                  • IT
                  Well,I removed R7820 too and still I have low resistance consumer side. There are a lot of capacitor on that PP1V_PRIM. I will try to test with ESR meter (tomorrow maybe). Thank you for your support.
                  • mon2
                    • Dec 2019
                    • 13830
                    There is also a cluster of pins on U7800 that directly bond to this rail (R12, T12, etc.) - so U7800 is still a suspect.​
                    Really interested to hear of your test results with the ESR meter. It is on my wish list. There is an excellent YT video on this topic and it is a no brainer to justify the purchase. Just scouting for a good quality one at a fair price.
                    • Pragmatiko
                      • Jul 2013
                      • 468
                      • IT
                      I don't know why, but I strongly believe that the problem is on R12,T12,U12..... of U7800 ic.
                      I've checked all capacitor under microscope. Usually bad capacitor is visible. I would be tempted to desolder the U7800.
                      • Pragmatiko
                        • Jul 2013
                        • 468
                        • IT
                        Found cause of low resistance. I've removed U1200.
                        Now I don't have low resistance but still I don't have PP1V_PRIM. Maybe cause is PCH not installed?
                        But I think 44ohm is normal value for PCH. There must be more
                        • grimacelord
                          Mac Mini Late 2018 |A1993| Fan Connector Damage & Lots of Weird Issues
                          by grimacelord
                          Hi guys.
                          I have a customer's Late 2018 Mac Mini in for a ripped fan connector after the customer tried upgrading his RAM.
                          Some pretty hefty damage occurred because the connector was ripped off entirely including all 6 pads for the fan connector. The connector on the end of the fan itself was also completely ripped off exposing all 6 wires. There is also an exploded component with what appears to be a resistor or filter. Not sure? (See pic). macOS also doesn't boot. Apple logo comes on screen and then moves to the question mark folder. Cannot boot from USB or Recovery...
                          05-30-2020, 05:52 AM
                          HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                          This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:36 PM
                          HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                          This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          09-12-2024, 02:20 PM
                          09-12-2024, 02:15 PM
                          HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
