ASUS RTX 3060 Ti Dual Mini - starts but no video
  • speaktorob
    • Mar 2024
    • 13
    I've already had a little help at r/GPUrepair to get me here. (kudos /u/khoavd83 ✊)
    At this point I'm trying to figure out if the GPU is a dead duck or not, but I don't have a thermal camera to perform the proper test. I tried the iso alcohol evaporation technique but it was inconclusive. Anything else I can try?
    The history of the card:
    Bought second hand, cleaned it up. Tried to make a fan mod with some noctua A9x14's. Got the wiring right -- at first -- but had problems getting the fans to fire up. When probing the fan header for voltages, I shorted something in the header. Also relevant: at one point I swapped the PWM and Tach wires to see if I'd got them the wrong way around. (I know, I know).​
    Relevant resistances:
    12V = 8.9kΩ
    5V = 225kΩ
    3.3V = 31kΩ
    1.8V = 11Ω (uh oh)
    MEM = 32Ω
    PEX_VDD = 50Ω
    GPU = 0.2Ω, GPU to 12V rail = 18kΩ
    Story so far:
    The header is a dual fan header with shared live and ground pins and two each of PWM and tach pins. Tach 1 shows only 60 ohms to ground (similar to the PEX rail). Tach 2 shows over 1k ohms. From reading resistances on other fan headers, it seems like the 60 ohms pin is the anomaly?
    I already found two 0 ohm resistors that showed 150 ohms that connected the 12V rail to the 12V pin, which I've desoldered (replacements inbound), but I doubt they are the root cause.
  • speaktorob
    • Mar 2024
    • 13
    Alright, so this is getting weirder.
    I can measure 60-65 ohms on the 1.8V rail, or I can measure 10 ohms, depending where I measure from.
    I've desoldered the inductance coil for the 1.8V rail to better figure out where the low resistance is coming from. When I measure from the solder pad going backwards to the VCC - nada, megaohms, all good. Measuring from the other solder pad going to the rest of the rail, its like 10 ohms to ground here. Same goes for the 6 capacitors in parallel next door that are presumably for frequency attenuation or whatever - they are 10 ohms to ground.
    If I measure from anywhere else directly on the rail, its 60-65 ohms.
    What gives?
    • speaktorob
      • Mar 2024
      • 13
      Anyone have an idea what to try next?
      * I desoldered the 1.8V coil and confirmed the low resistance is in the rail, not the voltage controller
      * The resistance is 10 ohms at the coil, but 65 ohms elsewhere around the board
      * I've examined the board but can't find any obviously dead components
      * I can't really inject voltage because I still have 10 ohms
      • User 4574
        Asus , board 532lws R1..3 Power rail 5v , 3v dsw
        by User 4574
        Hi everyone .
        I have model g712l And In stuck.
        Originally this laptop has a short on main Power rail . Thé main short is gone, i have found 2 pea16b mosfets Next to the SN51285ARUKR shorted , and the Chip Intself was Also shorted , i have removed them and main Power rail IS not shorted anymore , but right Now im still eating for this parts And in checking rest of the board . But pin 14 od the SN51285ARUKR when this chip od removed is shorted to ground Its +5VSUS has 6ohms , And that can not be , i have check mosfets All over the board And i have found ONLY one tahat ís shorted its...
        Bad cap
        0%
        0
        Shorted internal layer in thé motherboard
        0%
        0
        06-21-2026, 07:50 AM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • DaBomber4
        MS-15851 12v Power Rail and GPU fan header schematic
        by DaBomber4
        My laptop motherboard has a short that is cuasing the GPU fan header to be high by 12 volts. If you have the traces and schematic view, that would be awsome and I would greatly appreciate it!
        Thank you in advance!
        04-22-2026, 04:45 PM
      • Boardview and Schematic Bot
        NVIDIA GeForce RTX 3060 Schematic & Board View
        The GeForce RTX 3060 12 GB is a performance-segment graphics card by NVIDIA, launched on January 12th, 2021. Built on the 8 nm process, and based on the GA106 graphics processor, in its GA106-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3060 12 GB. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA106 graphics processor is an average sized chip with a die area...
        10-02-2024, 08:03 AM
        Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
        This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...
        09-07-2024, 03:10 AM
