I don't know the history on the card but at the key there is a small chip, see below. Looks like trace B10 3.3v and B11 React, A1 12v and A11 Reset is a little short but looks like it could still make contact. Here is exactly what it does. I was installing windows on a test PC to use with this, the card did put out video at that time uing the standard GPU (was an old version of Windows 10- v1510). Nvidea driver update said that op was too old for the latest driver so I updated to the latest windows 10 version. After fully updated Windows 10 was finished it doesn't put out video at all now. Using a riser board to test it. Hooked up to my standard desktop and it boots up using my main computer, I can look at Device manager and it does detect the GPU but is states "stopped due to problem Error 43. I do have nonconductive epoxy where I could repair the board and Silver conductive epoxy I could use to extend the trace but it seems like the PCIE socket should be still making contact. Any ideas for recommended first action? Should I start with the epoxy or tear it down and start testing resistances. I was trying to see how to put it in the PCIe socket and test continuity but can't see any of those trace tops so guess that means I need to tear down and find the first component touched by these traces to verify contact? Really appreciate anyone's assistance and advice here.
Gigabyte GV-N3070Gaming OC-8GD Powers on- Device manager sees it but "error 43 stopped"
Got MATTS to run. Showing bank A0 about 10 bits bad but B1 is all showing bad. Right next to each other. Thinking to try reflow before full reball. What temp solder do you find best to try. Air station temp 415c ish? 60% air? Preheat plate 100c?Comment
Reflowing what? the core?
The broken connections could either be the core or the memory chips, and since these chips are cheaper to replace, I would start by reballing them first and swap positions before doing anything to the core. If the errors follow the chip, then the chip is bad, but if otherwise then you can move on to reball the core.Comment
My new memory chips should arrive shortly and I'll try those. I have a cheap t862++ IRD or a much better Air reflow station, any thoughts which way proves easier to reball these? ***Also what the heck does this SW1 on the Gigabyte 3070 card do? I just got another 3070TI card which isn't being recognized and can't run MATS and I noticed that this switch is opposite of what the picture below shows???
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
02-09-2024, 08:08 AM -
by ProttHello,
I am having problems with Gigabyte Gaming G1 1080 that is visible in device manager (with an error). GPU-Z identifies it partially (has a name of the card, card ID, but lists revision as FF). Other info (voltages, frequency, etc.) spills from the remaining GPU that's used as primary display.
- Mats crashes with a segmentation fault.
- If I boot with the card as the only card I get no picture.
- All voltages are present
I swapped the BIOS chip, tried different BIOS revisions, but no luck. Is there any chance there's fault in something else... -
by momakaMore eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
And a shot of the label:... -
This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...09-07-2024, 07:19 AM
- Loading...
