On the VP6 between the AGP and first PCI slot there is a Jackcon 8x15mm, 16V, 1000uF capacitor. Is it safe to substitute a 10V capacitor there?
					Question about changing capacitor voltage on the VP6
 Re: Question about changing capacitor voltage on the VP6
 As a general rule, you should never substitute a lower-voltage cap for what was originally there. The original was 16V for a reason, and if you put a 10V there it could be subjected to more than 10V, and therefore bulge/vent. I recently tried applying 20v to a 10v cap, and the pic in my avatar shows the result.
 Replacing with a higher voltage cap is usually OK within certain tolerances.You know there's something wrong when you open your PC and it has vented Rubycons...
 'Ill second that......Tom41
 Having said that you will notice a few posts around the forum were people have been told they can use a lower voltage cap
 This only when the voltage is known to be lower 5 Volt or 3V3
 EG sometimes you will see a post were a 10 volt is use and they are advised to use a 6V3 cap
 The cardinal rule is that the Voltage rating of the cap must be higher then the voltage rail it sits across
 If its a 16 Volt cap it is probably across a 12 Volt line so a 10 Volt cap would be a no no but if its 5 volt supply line then a 10 volt would be fine...get the idea
 You can a lot of the time go a value or 2 up with capacitance, but it does depend on the use of the cap too
 What you tend to find is the size of caps becomes a problem with going up in voltage and capacitance.
 (size can be a problem anyway with Mother boards)
 Ideally with low ESR caps you want them to sit flush to the pcb
 I am not familiar with the PCB but I am sure there are a few of posts on it if you search these forums
 I know you are really looking for a ye or nay on this, I have a feeling there maybe a post about this somewhere here...anyway
 someone here will most probably know the cap you are talking, about its function and if you can use a 10V thought
 HTH cheersYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
 there are few posts and I did a quick look through some but did not find a conclusive ya or nay... just a doubt by willawake so you may get away with 10V
 Remember this is NOT a conclusive yes
 https://www.badcaps.net/forum/showthread.php?t=2489
 hopefully someone can confirm this for youYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
 Thanks, Tom41 and starfury1, I appreciate your efforts to keep me from doing anything calamitously irresponsible.
 Anyway, I did what I shoulda done in the first place. Got off my enormous fat behind and removed the VP6 from its case so I could measure the voltage at the point in question.
 From the condition of PSU on and power switch off through POST to OS it never exceeds 3.3V. So I think a 10V capacitor will give me a considerable margin of safety.Comment
 no worries...yeah that was going to be my other suggestion that I forgot to put in...measure it...
 bit funny thought using 16 v for 3V3 but Suppose its really a matter of buying power....You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
 Woo.. you use 16v caps evwerywhere?Originally posted by RainbowI use 16V caps everywhere too - bought a bag of 250 of them so it's cheaper and no need to have various types.
 I have tested when used with all 16v caps on a mothbaord. The result is that the boot screen will appear slower than before.
 I guess the reason that higher voltage caps need to more time for charging the caps, right?Last edited by Big Pope; 01-18-2007, 07:05 PM.Comment
 No a higher voltage cap (of same size) will have lower capacitance and charge faster. YOur result with a slower boot screen is really strange, not what I've seen and I also use a lot of 16V caps whenever reasonably possible.Comment
			by MORETTIGIANTitle:
 Description:
 Procedure performed:
 - Removed backplate
 - Reapplied thermal compound
 - Reassembled card
 - GPU powers on and operates normally under...11 Photos
			by chth96I have an 21 inch CRT TV which is not able to power on.
 I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
 It shows 270V on my DMM.
 So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
 Then I desoldered this main filter capacitor from circuit board.
 But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
 I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...-
			by Per Hansson(TL;DR skip the first paragraph)
 I encountered my first dead motor run capacitor at a customer this week.
 For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
 (Unless a servo motor makes more sense that is).
 But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
 The pump would run but sometimes trip the 10A breaker.
 I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
 Then it could...
			by sam_sam_samThis is a new item at Battery Hookup that I bought I have always wanted to buy a good capacitor battery stud welder but they are to expensive for my budget that I want to spend on one this was surprisingly moderate price for what it can
 It came by FedEx today so I decided to try it out on some tabbing that my battery stud welder has a little issue making constantly welded with out having to redo some because it would not get hot enough to do it properly
 Well right out the box when the super capacitor charges up with the setting as follows does a very good job the first...
			by sam_sam_samThis is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
 Found a 47uf@63 volts double the ESR value of a new one
 The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
 The main filtering capacitor was not replaced because I did not have that was not too tall
 Where the 220uf capacitor is some type of switching power...08-30-2022, 05:28 PM
- Loading...
