Gigabyte R9200 (GV-R9264DH) and Zalman VNF100 cooler
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    On graphic card Gigabyte GV-R9264DH (Radeon 9200), witch give me some SW installation problems, I tried install solid yet passive heatsink. I picked up Zalman VNF100, because it draw the temperature on upper side of gfx card, witch is good for moving the heat away. Also there is the heatsing a bit cooled down from the air movement from CPU cooler. So even the heatsing is far superior for such old card, witch did not overheat much at all, I got in the end a very cool card, been sure that the 2D artefacts it displaying ( http://www.techpowerup.com/forums/sh...d.php?t=170954 ) did not come from overheating or bad heatsink to GPU contact. And finally, no fan can be heard now from it
    Whole look at the installation:
    It is not entierly true, that the VNF100 cooler can be used on all R9xxx cards, as Zalman claims - Gigabyte design put one small cap slightly into the way:
    I decided don't bend the cap or push the cooler on it or move the cooler more to the right but rather saw off a little of the two fins:
    Cluster of TEAPO and one GSC cap - they are IMHO responsible for the minimal yet existing 2D graphic quirks:
    On back of the card there is one more TEAPO cap:
    Main caps are, luckily, Nichicons HM
    And also Nichicons HC:
    Look from the top of the card is nice, I pulled off the Zalman off his logo, to make the airflow better (unrestricted):
    One more look at the cluster of TEAPO caps:
    Complete lookat the back side of the card - in the fins, there are there plastic dilatation support spacers, to ensure the cooler did not touch the card from back. However if you slap these small coolers on the memory chips, then it is very likely you have to remove the middle spacer:
    In the overal, then nothing stand in your way - only the heatpipes not insert all the way into the base, at least not on Soltek KT600-R mainboard. Because there can be then collision with the top of the ram installed in 1st DIMM slot. That will then prevent you insert the card properly into AGP slot. After all, even the relatively big cooler can be used in computer w/o any problems - except for the two fins on the GPU base on this particular card...
    Gigabyte GV-R9264DH card use these caps:
    3x 1000uF 6.3V Nichicon HM d8
    2x 470uF 10V Nichicon HC d10
    1x 100uF 16V GSC d5
    9x 100uF 10V TEAPO d5
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    Re: Gigabyte R9200 (GV-R9264DH) and Zalman VNF100 cooler
    The small caps arrived, so - time for recap! Instead of Teapo and GSC, now there are Panny FM & Rubycon LZH caps:
    And it is no wonder, that the Teapos did not make it. Well, they are almost 2x smaller that Panasonic! (Teapo 100uF 10V, Panny 150uF 6.3V) And who ever seen, that some Teapo company, notoriously known to produce bad caps, can made 2x smaller cap that Panasonic can
    And now is the time for some stability testing
    Sadly, still the graphic quirks are there:
    • luke10050
      • Mar 2013
      • 209
      that looks pretty damn good, i like the gigabyte cards with zalman coolers. ive got one in my main pc and apart from the fan being stuck on 100% it is pretty damn brilliant... gj on the recap so far. also, that could be a graphics core problem, tried the oven trick yet haha? but seriously, you may be in for a bit of a ride if you dont know anything about BGA rework. i think that card is around the time where they switched to leadfree solder... i'd give it a try. only thing is dont heat up caps too much... they can go boom (if you go the oven method anyway, i would not recommend it unless you are desporate)
      • trodas
        • Jan 2006
        • 770
        • Czech republic
        luke10050 - thanks. I did not fancy any card maker in general, but I do fancy a good quality caps
        Fan stuck at 100%? Damn shame. Time to replace the fan then
        As far, as the problem goes - please bear in mind, that the 3D rendering is (or more likely was, read bellow) pretty fine:
        ...so I did not believe that the graphic quirks are caused by anything on the card anymore. And I believe the card did not use lead-free solder yet. Too old for that
        So, since the card still show certain (shown above) quirks in graphic, I decided to fix it by finishing the recap of the bigger caps. It also started even blacking out the image, when on website there is a flash or some moving animation... So it looks like that the card is dying (at least from this point of view).
        So I choosen replacement caps to be Nichicon FP polymers, with little capacity bump when possible - they got amazing ripple currents - 5700mA and even 6100mA for the d10 ones:
        Gigabyte Radeon 9200 (GV-R9264DH)
        3x 1000uF 6.3V Nichicon HM d8 - 5x Nichicon FP 1000uF 6.3V d8 (Digikey.com 493-4024-1-ND)
        2x 470uF 10V Nichicon HC d10 - 2x Nichicon FP 1000uF 6.3V d10 (Digikey.com 493-3710-ND)
        1x 100uF 16V GSC d5 - Rubycon LZH 100uF 16V d5 (Digikey.com 1189-1148-ND)
        9x 100uF 10V TEAPO d5 - Panny 150uF 6.3V d5 (Digikey.com P12917-ND)
        So todays I finally soldered them into my card. I filled even the two empty spaces, however I choosed a d8 caps and there is the holes for d10 cap, so these caps are a bit higher over the board then... But it still looks pretty nicely, at least I think so?
        There are the little d8 Nichicon FP polymer near ram:
        Two empty spaces are no longer empty:
        All these nice polymers in one shoot:
        ...and a detail view of the two "main" d10 1000 FP Nichicon polymers, where are before questionable and only 470uF caps, maybe real Nichicons, but who knows?
        And results? Well, the card is working, the blacking of the image stop, however the quirks are still there. Just use ATItool and the monitor turn completely black, when the rotating box should appear...
        So it looks like the primary cause had to be searched in the mainboard Soltec KT600-R and w/o exchange of caps on it we did not get any far with it.
        This is unfortunate.
        Why most of the hardware is have bad caps?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          People want cheap stuff - people get cheap stuff!
          BTW, that fan 'problem', is most likely the fan controller and not the fan itself. Hey, the extra cooling should make the card last a little longer...
          Muh-soggy-knee
          • trodas
            • Jan 2006
            • 770
            • Czech republic
            Indeed, but it looks like it does not need much cooling in the first place:
            I just testing the Radeon 9200 in another mainboard (rather old yet recapped suxxka - JetWay V266B - a VIA KT266A chipset, it even support SDRAMs and did not like FSB over 133MHz - it is rock stable at FSB 150, yet the IDE access become unstable, at FSB 152 no boot to Windows... gotta check if disabling 32bit access won't help a bit for faster FSB, tough) and it works just perfectly.
            Not a sign of error after over 7 hours:
            ...and the card is only mildly warm, despite being just on the desk, with no fan around ...!!!
            (But it is true, that the fps of the cube is like 33fps, witch is - sort of - minimal. Even mine AGP PNY GeForce 6800GT can go over 300fps when no other apps are running around - check the average FPS 334: http://postimg.org/image/x9m8pl4sl/ - so the performance level is a joke )
            So after that overnight torture, I just run 3DMarks - the score is laughable, because the machine is laughable too - 133x11 and Thorton core? Come on...
            ( http://www.hwinfo.com/forum/Thread-S...t-JetWay-V266B )
            But the main point is, that the card works well and perfectly - and very very cold. It is still not even hot and it run some Duke3D demos (the Duke port, of course) nonstop.
            Therefore any problems I encounter is the problem with the Soltek mainboard. I already noticed two bulging (and of them even leaking) Chemicon KZG caps, so recap is in order
            Card is more that fine
            • DynaxSC
              GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
              by DynaxSC
              I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
              General test conditions:
              - Tested with Core i5 6500 and Core I7 6700K - no difference
              - Default BIOS settings, but tried also altering several memory setting - does not change anything
              What is wrong:
              With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
              When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
              03-21-2025, 06:23 PM
              Thermal pad thickness for various laptop GPU / Graphics Cards
              ASUS Dual RTX 2070 OC 8GB
              ASUS ROG STRIX RTX 3080 OC
              ASUS ROG STRIX RTX 3090
              ASUS TUF Gaming RTX 3080 OC Edition
              ASUS TUF GTX 1660 S-O6G GAMING
              EVGA RTX 3060 Ti XC GAMING 8GB
              EVGA RTX 3060 XC GAMING 12GB GDDR6
              EVGA RTX 3080 FTW3 ULTRA GAMING
              EVGA RTX 3080 TI FTW3 ULTRA GAMING
              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
              Gainward RTX 2080 Phoenix GS Specs
              Gainward RTX 3070 Phoenix 8GB
              Gainward RTX 3080 Ti Phoenix
              GIGABYTE AORUS RTX 3080 MASTER 10G
              02-09-2024, 08:08 AM
            • nikovmiroslav
              Gigabyte A5 X1 Need Bios
              by nikovmiroslav
              Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
              Gigabyte A5 X1
              From motherboard:
              S/N: 1TNH55ER1350895
              P/N: 6-77-NH55ERQY-D02-2CGB
              On sticker from the back of the laptop:
              S/N: SN21351J000657...
              08-24-2025, 09:15 AM
              Gigabyte Notebook Specification for Upgrade or Repair
              This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
              09-07-2024, 07:19 AM
              Gigabyte G series G5 KF-5 Notebook Specification for Upgrade or Repair
              This specification for the Gigabyte G series G5 KF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 KF-5 boardview and G5 KF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
