TH7II raid capacitor replacements
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: TH7II raid capacitor replacements
    The PSU I have is noisy ...
    Sounds like the fan in your P/S may be failing (are you sure it isn't the CPU fan?), which could reduce cooling. Also, if I understand correctly the cap has been in use, more or less, 24x7x52x5, so it could have been an end of life failure.
    PeteS in CA
    • jo-jo
      • Dec 2006
      • 12
      Ok, well it is not noisy, it is quite quiet, I just want it to be more quiet as this one is supposed to spend the rest of its life in the living room.
      To my knowledge there is no foreign metal in there (I inspected it carefully last night), the case is well vented, has 3 fans drawing air through the back, plus the one in the PSU.
      If the poorly seated sound card is not the culprit here, then I just have no clue as what might have caused this.
      • Operandi
        • Jul 2006
        • 46
        Five years is quite awhile but as long as the cooling is at least adequate I would expect them to go for much more then that. It looks like you have a Zalman 7xxx heatsink on the CPU so cooling around the CPU caps should have been very, very good which would only prolong their lifespan.
        If it's not a power issue I would just assume that you have a rare "dud"; since you will be replacing the PSU anyway you should be covered either way.
        For the PSU I would recommend the Seasonic S12 (the 330 watter should do) for it's build quality and extreme quietness.
        • PeteS in CA
          • Aug 2005
          • 3581
          Just remember that quieter fans tend to be lower airflow, which means higher temps and shorter component lifespans.
          PeteS in CA
          • jo-jo
            • Dec 2006
            • 12
            You can compensate for that by using larger fans, at least up to a point, and if you are willing to mod your case a bit by cutting a hole close to the PSU and fit an airduct (thin aluminum sheets are fine for that) over it which brings the outside air directly to the PSU intake, then you are in pretty good shape.
            I have done that with one case, and actually I don't understand why they aren't designed that way to begin with. I plan to do this to my Ahanix when I have the time.
            • jo-jo
              • Dec 2006
              • 12
              #26
              Caps came today, thanks Chris, and I put them in. It was pretty straight forward thanks to the good guidelines here on this site.
              However, in the meantime since Chris sent the caps, I tore the machine apart and found out that there were bad caps on the videocard as well. Could that have caused this?
              Anyway, I put the cpu back on and the memory, and plugged an older card I have in. Now when I boot up the board sounds the annoying sirene alarm. When I checked the fanspeed, cpu temp and voltage in the monitoring program provided, it turns out that the Vcore voltage is too low, and that the +12V is low too, thus causing the alarm. And when I think about it (keep in mind that this is an old machine) this happened also many years ago (another PSU), and then I just lowered the lower limits and forgot about this, just assumed that the defaults in the monitoring program were set wrong to begin with. This was probably 4 y ago at least, and everithing ran fine since then until the caps blew few days ago.
              So my question is: Is it possible that *too low* voltage can cause any damage like popping caps? Isn't it more likely that my caps blew because of the videocard? The ones that got damaged are close to the AGP bus.
              OR... can that voltage problem be caused by my bad soldering? I mean, if I did not do that properly, the machine would simply not start - right? There is no way that a badly soldered cap can cause V fluctation? I actually think that I did this pretty well, and I am used to soldering, just not on multilayered boards like this is.
              • Rainbow
                • Aug 2005
                • 1375
                #27
                Check the PSU for bad caps too.
                • jo-jo
                  • Dec 2006
                  • 12
                  #28
                  I did check it last night and the PSU is fine.
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • slybunda
                    Gemcon capacitor replacements?
                    by slybunda
                    taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                    there are 2 caps which im looking to get replacements for.
                    Branded as Gemcon
                    single 100uf 16v 6.5mm x 11.5mm
                    single 100uf 50v 8mm x 11.5mm
                    lead spacing is around 3mm
                    there is space for 16mm tall caps
                    rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                    the caps have...
                    02-05-2024, 03:36 PM
                  • tbalint3
                    Abit ST6-Raid repair
                    by tbalint3
                    Hello All,
                    I am trying to repair an old Abit ST6-R motherboard.
                    The symptoms are the following:
                    I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                    It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                    If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                    09-01-2024, 10:03 AM
                  • burom
                    Xbox 360 Xenon Modern Capacitor Replacements
                    by burom
                    I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                    I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                    06-07-2024, 05:10 PM
                  • Agent24
                    Dick Smith Q-1760 linear power supply filter capacitor question
                    by Agent24
                    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                    It has at least one problem.
                    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                    I have already ordered a replacement potentiometer, so that's not an issue.
                    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                    All are CapXon...
                    10-21-2025, 05:39 PM
