TH7II raid capacitor replacements
  • jo-jo
    • Dec 2006
    • 12
    Hi
    I have the mobo above and have had it for 5 (?) years and it has been running more or less 24/7 all that time. Yesterday I noticed that two of the capacitors on it are starting to leak and I guess it will fail in the near future. Is there any place where I can find the specs for all the capacitors on this mobo?
    I could figure this out myself by taking it out of the case, but I would like to avoid that until I have the replacements.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: TH7II raid capacitor replacements
    Post the brands, values, and series. Post some pics as well if you can.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • jo-jo
      • Dec 2006
      • 12
      Well, it is kind of hard to see while it is in the case, I was hoping there was someone who knew what type of caps are on the ABIT TH7II Raid mobo (sorry I forgot to include that this is ABIT in the first post) so I didn't have to pull it out before I have the replacement.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Abit used quite a selection of crappy caps, ranging from Teapo, Jackcon, and Teyah, all of which are known to fail. Their later boards use Rubycon MCZ and MBZ mostly, which won't give you any trouble. I'd replace all the caps 1000uF and up, even if they aren't showing signs of failure.
        Team : 49813
        Join in!!
        Team Stats
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          I think he's looking for a list of uf and voltage values for all the caps on the board, Topcat
          Sorry, we can't do the hard work for everybody
          Ludicrous gibs!
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            lol... If that's the case, just pop the board out of the case and take a look, it'll have to come out to be recapped anyway...
            Team : 49813
            Join in!!
            Team Stats
            • jo-jo
              • Dec 2006
              • 12
              I was just hoping that somebody had already been through this with that mobo and shared the list somewhere, so I could just go out shopping before ripping the machine apart.
              • jo-jo
                • Dec 2006
                • 12
                OK here goes. I seem to have
                4x2200uF 10V (TEAPO)
                6x 1000uF 10V (TEAPO)
                6x3300uF 6.3V (MBZ)
                It is only the last ones that are leaking (see image). Where is the best place to buy good ones of these? Also, I am used to soldering, but I have never done it on a "multilayer" mobo before. What are my changes of screwing everything up?
                At the bottom of it there is a metalic cylinder, labelled HD J1, 1200, 16V. What is that? Does not look as a cap to me.
                • Operandi
                  • Jul 2006
                  • 46
                  Here is a pretty good shot of the board.
                  It looks like they used Nichicon and Rubycon around the CPU (good), at least in that sample.
                  Around the RAM looks like Teapo (less good).
                  It doesn't look like finding replacements should be a problem size wise. Which caps failed?
                  • jo-jo
                    • Dec 2006
                    • 12
                    The ones around the CPU - the ones you say are good
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      Wow, that exploded one in the pic is a Rubycon! I would look for some shorted FET's or PSU issues, that's definitely not a typical occurrence! It vented with a vengeance, so I'm willing to guarantee there's other trouble on your board or PSU.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Operandi
                        • Jul 2006
                        • 46
                        Hmm... I wasn't expecting a post so soon. Should have refreshed....
                        The metallic object is a cap, a Nichicon I believe. It looks different because it lacks the jacket covering most other capacitors.
                        From that picture it looks like the Rubycon failed which I've honestly never heard of happening.
                        What PSU are you using with the system? I ask because a low quality PSU can cause capacitors to fail prematurely due to excess ripple and/or over-voltage.
                        • jo-jo
                          • Dec 2006
                          • 12
                          OK. Here is the whole story: This mobo has been in various cases with various PSU's, for most of the time it was powered by one from PC Cooling if my memory serves me correct. This has been my main work machine and has been left on day in and day out, so it has been powered for about 5 years, constantly. About 2 mo ago I transferred it to its current case, an Ahanix D4 - it is a media server now, and still runs 24/7. It was fine then, I did inspect it carefully. I believe the Ahanix has a PSU either made by them or for them, at least the label just says "Ahanix".
                          The funny thing is that the mobo still runs fine, as a matter of fact I am writing this on that machine, but I am sure it will fail pretty soon.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            Stop using it until that cap is replaced. It could cause more serious damage if continuing to use it. I would also replace that no-name PSU. The problem will not go away on its own.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • jo-jo
                              • Dec 2006
                              • 12
                              I actually think I know what happened. I installed a new soundcard when I transferred the mobo to this case. It did not work at first and I was too lazy to do anything about it. Yesterday I decided finally to fix that, thus opened the case and saw the leaking caps. It turned out that the soundcard was not seated properly. It may have shorted out some contacts I guess being so poorly installed. Could that have caused this?
                              The PSU I have is noisy, and I plan to replace it soon, and thanks for the advice, I'll switch to the other machine.
                              Where is the best place to get good cap replacements?
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                If you're in the US or Canada, shoot me a PM, I can get you some replacements.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Operandi
                                  • Jul 2006
                                  • 46
                                  I wouldn't think that would cause the capacitor/s to fail, especially when the cap that failed is near the CPU and not the PCI slots.
                                  Regarding the PSU by "PC Cooling" maybe you mean "PC Power & Cooling". If thats the case those are top-tier units and very unlikely to cause problems. If it's some other brand.... who knows.
                                  Ahanix are the high-end media center cases correct? I believe their PSUs are OEM'd by Forton-Source so at the very least they are of decent quality.
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    I didn't know that... I stand corrected if that's true. That single cap going could have been caused by any number of things, a power spike, overheating, fault in the PSU, or the cap itself could have just been a dud, (it happens once in a blue moon). Still, don't waste any time replacing it. Since the board still works, you can rule out any voltage regulator/FET problems as the cause.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • jo-jo
                                      • Dec 2006
                                      • 12
                                      Yes you are right about the PSU's, and Ahanix is highly rated for quality media center products. My cases have always been very well vented, so cooling problems should not have caused this.
                                      • Tom41
                                        • Oct 2005
                                        • 336
                                        • England
                                        Just make sure the blown cap is not a Rulycon (counterfeit Rubycon)! If it is a genuine Rubycon, it was probably exposed to excessive heat and/or ripple current from something else on the board. Did any of the cooling fans fail for a period of time? Is there any foreign material on the board that might be causing a short near the cap?
                                        You know there's something wrong when you open your PC and it has vented Rubycons...
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
                                        • rattlesnake
                                          AC Adapter: blown capacitor, possible replacements
                                          by rattlesnake
                                          Hi folks,
                                          I'm repairing this old AC adapter and noticed it had a leaked cap, removed it, cleaned the surface (very nasty smelling) and now I'm trying to look for a replacement, but the values aren't quite standard or at least I don't have them readily available.
                                          Any suggestions or guidance? I like learning about this.
                                          Is there any chance to use a capacitor with a different value?
                                          Capacitor info:
                                          68uF 35V
                                          Size:
                                          20 mm tall
                                          11,4 mm wide
                                          I included some pictures. It seems the traces involving this capacitor had...
                                          02-17-2021, 07:08 PM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • afarr
                                          Apple MacBook Pro Mid-2017 A1706 - C7490 Capacitor Help
                                          by afarr
                                          Hi all, this is my first post, I offered to check out a friends MacBook Pro, A1706 which doesn't power on, before this happened they smelt something burning inside, and Apple refused to help with out being out of warranty.
                                          Among investigating a capacitor on the logic board spilt and scorched surrounding area please refer to images; https://imgur.com/a/AmSwFr3
                                          I found a schematic (x362 MLB Schematic) for the logic board on a thread from this site, I'm unsure about the right terminology when describing so please forgive me.
                                          On the location I assume...
                                          02-13-2023, 01:11 PM
                                        • canadaboy25
                                          Drive SMART status not showing up through RAID controller?
                                          by canadaboy25
                                          Hey guys,
                                          I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                          Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                          I rebooted...
                                          09-24-2021, 01:56 PM
