issues recapping a dc7700 usdt
  • cashkennedy
    • Aug 2011
    • 668
    Im recapping some hp dc7700's from ucc kzg series caps to some nichicons and panasonic caps. First board I did worked fine after. Second board went much faster but no video output on boot, and doesn't appear to boot completely (hard to tell since they do a long mem test after removing the cmos battery)
    I resoldered all the caps and have the same problem. I decided to test them with my multimeter to look for any differences / dry joint issues, and while 6/7 caps have the standard reaction for resitance check where it beeps for a second and then climbs out of range, 1 cap on the other hand has a steady 18 ohm resistance, should I assume that I soldered that cap wrong (might have solder touching another trace)? or consider that I might have destroyed the cap since it gave me a lot of trouble soldering it / and took like 5 seconds to solder it vs the .5 seconds on most of the other caps.
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: issues recapping a dc7700 usdt
    You can try taking it back out and checking the resistance between the pads again (and maybe the resistance of the cap too).
    • cashkennedy
      • Aug 2011
      • 668
      I used some wick to remove some of the solder on that joint, and it no longer reads a steady resistance, now it charges / goes out of range for resistance. The motherboard still doesnt work though: still shows no video and doesnt appear to be booting completly. Ill probably swap out some of the other caps again / but this board isnt invulnerable so im worried ill only be able to solder / unsolder the caps 1 or 2 more times.
      • retiredcaps
        • Apr 2010
        • 9271
        I find one of these useful for less than $2 USD + Free shipping. It gives a clue where to look, but not all the time.
        http://www.ebay.com/itm/310662804829
        --- begin sig file ---
        --- end sig file ---
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Check the resistance of the same cap on a working board. If it's for the chipset, chances are it will (and in most cases should) read low resistance.
          • cashkennedy
            • Aug 2011
            • 668
            Wow I didn't know those 2 number post displays were a like universal type of device / I have plenty of nicer motherboards with those (evga / abit).
            And thanks for the good idea Momaka, I will compare to some of the other dc7700's I have and report back.
            • unseen
              • Oct 2013
              • Iceland
              I have the same problem with my motherboard (HP DC7700 SFF)...
              The computer starts but I get no display and it will not boot..
              I have changed few of the capacitors (1000uF 6.3V) which looked bulged on the top, two had a small visible leak on the top.
              I still have the same problem, the motherboard will not boot and shows no action through the display
              • cind12
                GTX 1080 TI Gigabyte Aorus low resistance on vmem
                by cind12
                Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                Resistance on 12V 4K ohms (Power present when on)
                Resistance on 12V PEX 4K ohms...
                12-08-2023, 09:09 AM
                HP EliteDesk 800 G1 USDT EliteDesk 800 G3220 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G1 USDT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G1 USDT boardview and EliteDesk 800 G1 USDT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-12-2024, 03:30 PM
                HP Compaq Elite 8200 USDT Compaq Elite 8200 i5-2400S Specification for Upgrade or Repair
                This specification for the HP Compaq Elite 8200 USDT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 USDT boardview and Compaq Elite 8200 USDT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-12-2024, 03:28 PM
                HP Compaq Elite 8300 USDT Compaq Elite 8000 i5-3570S Specification for Upgrade or Repair
                This specification for the HP Compaq Elite 8300 USDT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8300 USDT boardview and Compaq Elite 8300 USDT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
