Will these caps work for a VP6?
  • Shenes
    • Jun 2004
    • 8
    My VP6 has been kind of flaky since day 1. Not many crasches, one or two in a month perhaps, but it almost never posts directly at powerup. (When I have crashes they're almost always complete system frezes.) I have to power up, wait for a minute and then reset and then it posts and starts as normal (if i reset to quickly it usually posts but then freezes during boot up). I've tried switching power supplies, took out/switched around memory modules and upped the voltage but to no positive effect. Then I found this site... And to little surprise I found that a lot of the caps had bulged tops. Therefore I'm up for a transplant.
    The problem is that I'm unable to find direct matches for the caps here in sweden. This is what I found on the swedish site http://www.elfa.se
    Sanyo low impedance miniatures:
    1000 uF 10V D: 10mm H: 16mm
    1000 uF 16V D: 10mm H: 20mm
    1500 uF 25V D: 12,5mm H: 25mm
    So I guess the 1000uF's are OK but how about the 1500uF's, will they work fine? Are they gonna fit in without too much trouble. (all the legs are 0,6mm diam.). I'm not aiming to win a beauty contest here...
    grateful for any help,
    Johannes
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    To recap a VP6 correctly and fully, 23 caps need to be replaced. The 1000uF caps will be OK. However, the 12.5mm 1500uF caps will be a very tight fit if not impossible. A 12.5mm cap will not fit between the AGP and PCI slot1, and that one is critical to be replaced. I'd hunt down some 10mm 1500uF caps, and you'll be set. Another footnote, you might have to install the caps between the AGP and PCI slot1 on their sides. The height of the replacements can interfere with heatsinks on graphics cards making them not fit in the AGP.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Shenes
      • Jun 2004
      • 8
      Wow, that was fast
      If you say so I'll take your advice. It was just that some guy on the forum succesfully recapped his MB with caps from ELFA and I guess he would have to use the same 1500uF's that I've found (I tried to contact him, but no reply yet).
      But apart from the size it's ok to use higher voltage rated caps?
      Can anyone recommend me a good european dealer?
      best regards,
      Johannes
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Since you're in Sweden, your best bet is www.digikey.com. They will ship internationally. They're a bit on the pricey side, but your VP6 is well worth it!! You couldn't replace it for less, and this will permanently cure it of bad caps.
        Yes, it is OK to increase the voltage rating of the caps.
        Team : 49813
        Join in!!
        Team Stats
        • Shenes
          • Jun 2004
          • 8
          Ordered Rubycon caps from Farnell on friday and got them on monday. They don't have a minimum order like digikey + they ship from europe = a lot cheaper!
          http://www.farnell.com
          The only "bad" thing about farnell (sweden) is that I had to call their office to get a customer ID to be able to order online.
          Now I just have to plan for a couple of days of downtime to do the transplant...
          regards,
          Johannes
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
