MSI BX3 (MS-6120) - Bad Caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Here's an old MSI BX3 dually slot-1 motherboard with fried caps... This came out of a server for rebuild, far less than the replacement/upgrade cost would have been despite its age.
    The bad caps are 'Chhsi' brand (no surprise). This board required a bunch of caps! I ended up replacing 37 caps total. It now works perfect, which in turn will make its owner happy.
    Caps replaced as listed:
    (6) 1500uF 10v 10mm
    (15) 1500uF 6.3v 10mm
    (16) 1000uF 6.3v 8mm (I used 10v replacements)
    BEFORE:
    AFTER:
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
