Help Me Find A Replacement MOSFET
  • mockingbird
    • Dec 2008
    • 5484
    I have an MSI P45-Neo3 with a blown Niko Semiconductor, model P45N02LDG, with some guts spewed on a nearby FPCAP. Thankfully, the failure caused the MOSFET to seperate from the tab, so I will just have to desolder the leads.
    I cannot find an exact match to it. From my limited knowledge of these things, I ascertained that it's form and package type is TO-252 DPAK, two-leads one tab.
    Specifications:
    VBRDSS:25
    RDS:20 milliohms
    LD:45A
    I tried looking at some ST Microelectronics equivalents on Digikey, but all these numbers and abstract electrical specifications are enough to confuse anyone.
    Can someone lend a hand please?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Help Me Find A Replacement MOSFET
    I found something nearly equivalent:
    ON SEMI NTD40N03R, but the "On Resistance RDS" is only 12 milliohms instead of the Niko's 20 milliohms. Is this a suitable replacement?
    • kikkoman
      • Jul 2007
      • 691
      i'd say you're good to go.
      a lower Rds doesn't matter at all (it should even lower losses a bit).
      the other specs (threshold Vgs, rise time, Qgs, PD) are fine too.
      make sure you get that thing soldered down well and hope the rest of the circuit is undamaged.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • jm942
        Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
        by jm942
        My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
        I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
        I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
        I did voltage injection on the cpu with 0.7V and i have a current...
        07-11-2024, 05:11 AM
      • samoelec
        Trying to understand how to find best replacement cap for old parts.
        by samoelec
        Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
        Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
        The power supply board is exactly the same from this post so I'll just steal it for now.
        I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
        04-01-2024, 03:39 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • Oliver111
        Asus UX535L.Help to find name of mosfet driver
        by Oliver111
        Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
        04-08-2024, 07:47 AM
